09-26-2018, 03:17 PM | #113 |
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV Join Date: Oct 2014
The MOST control information comes from the HMI module I believe. Not the screen. With that said, it would probably have to be programmed to include that data / capability.
2018 2SS Vert - Hot Wheels - Indy 500 #30 2017 ZL1 Vert - M6 , SIM, CFW, NAV 2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-( Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 - Heads-Up Display - DIY 2011 CTS-V - Black / Black - SOLD. :-( 2013 ZL1 - Black / Black - SOLD. :-( 2010 2SS - Indy 500 Pace Car. - SOLD. :-( 2002 Z28 - Pewter / Black - SOLD. :-( |
09-27-2018, 11:36 AM | #114 |
Drives: 2016 Camaro RS Join Date: May 2016
Good info nitro. So the hmi needs to be programmed for it then the connection for the most info from hmi to cluster must be made? So the same pin outs etc for most control should be the same?
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
09-27-2018, 11:39 AM | #115 |
The wiring definitely needs to be there. I know when I did my upgrades, it was mandatory.
10-30-2018, 07:01 PM | #116 |
Reviving this beast.....Chris, been waiting on a cluster to show up on ebay...found two but have discontinued part numbers. Do you have a list of part numbers by year? They say they're for a 16' but want to make sure.
11-02-2018, 10:47 AM | #117 |
I hack cars.
Drives: Lots ;) Join Date: May 2009
Contact us from our website we can check fitment.
Chris White
Some uhhhh cars. |
03-16-2019, 06:11 PM | #118 |
Drives: 2017 black Camaro RS convertible Join Date: Nov 2018
Any new news on the harness?
03-19-2019, 09:34 AM | #119 |
I hack cars.
You should contact Gen5DIY directly.
Chris White
Some uhhhh cars. |
03-28-2019, 08:53 AM | #120 |
Alright time to get this going again. starting from the top.
I'm going to buy an SS cluster for my 18 1LT. Is there anything I need to look for specifically because I saw someone talk about discontinued part numbers. Is it an easy install and if I contact Gen5DIY will they give me the harness to make sure everything is working properly as far as it can with the 7" screen? I use my steering controls a ton. |
04-01-2019, 12:47 AM | #121 |
Drives: SS12 Join Date: Aug 2016
Fantasticooo ,, I do appreciated if you write all steps and if there's a video will be much easier to follow you buddy!!
Thankssss alooot |
04-23-2019, 04:28 PM | #122 |
Drives: 2017 Camaro RS Join Date: Mar 2017
Radio Swap
Any news on the Radio Swap? (7-to-8inch)
04-24-2019, 08:13 AM | #123 |
04-25-2019, 12:00 PM | #124 |
Call them its easier.
08-25-2020, 08:57 AM | #125 |
Drives: 2017 Camaro V6 RS Join Date: Apr 2014
Just got mine installed. I used the harness from gen5diy to get everyhting to work properly.
08-25-2020, 09:05 AM | #126 | |
Thread Tools | |
