Old 10-14-2020, 09:59 AM   #1
parish8
Drives: 17 SS a8
Gen v 5.3 high boost low budget build
I dropped a valve last year on my 6.2. It had drop ins, head studs and some valve train stuff and made nearly 1100hp. I have been debating in what to replace it with for awhile.
To keep me busy I went ahead and dropped a stock gen v 5.3 in the car. It has been fun to play with and has allowed me to finish other mods I had planned like an air to water intake and chiller set up.
I have no idea what a 100% stock one of these will take. We took it to 15psi and made 678hp. Seems decent to me. The chiller is working well, look at the mat in the pic below! It does have some condensation issues when the weather is warmer.
The plan is once the weather turns crappy to swap in some drop ins and some valve train parts and reuse a few parts from my 6.2 like the cam and head studs and then give it hell. Like 30+psi hell. It should be fun. These motors are stacked up at the junk yards around here and can be had for $1000-$1700 depending on miles.
Old 10-14-2020, 11:15 AM   #2
gtfoxy
Drives: '21 Wild Cherry ZL1
In! on what will no doubt be a legendary thread.
Old 10-14-2020, 12:35 PM   #3
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
All his threads are. He tinkers like an old mad scientist who never would retire, wife thinks he's crazy and has proof but doesn't know how to help him. So she just leaves him alone in his garage knowing at least he's not out chasing women. Right Parish? Foxy, no I'm not drinking. Forgot to ask will this be a stock bore 5.3?
Old 10-14-2020, 01:12 PM   #4
parish8
Drives: 17 SS a8
Stock bore, just the gpi drop ins. No balancing. No head work.
The head work part bothers me a little being that I dropped an exhaust valve on the 6.2. I looked into getting them done and every route seemed to add up to a lot of money. I am pretty sure the 5.3 does not have hollow stem exhaust valves. That seems like it should help.
Does anyone know if the 5.3’s in stock trucks have a history of dropping valves? I have heard it isn’t uncommon in the newer trucks but was thinking that was for the 6.2 motor.
Old 10-14-2020, 02:09 PM   #5
laynlo15
laynlo15's Avatar
I think they are pretty stellar and make great power when boosted. You always see a lot of 5.3s at the track with Turbo's. Probably the most popular boosted motor out there right now. As you said they are everywhere and priced right. Good luck
Old 10-14-2020, 02:13 PM   #6
parish8
Drives: 17 SS a8
I believe you are talking about the gen 3/4 5.3. Those are well proven. This is the gen v DI motor. There is less known about these engines.
Old 10-14-2020, 02:46 PM   #7
Choda
Drives: Turbo 6.2
what did your factory 6.2 and drop in 6.2 make at 15psi? I'm very very temped to follow suit with your lead. The 6.2 over head cost is still stupid expensive. I don't really care about the cubes, I care about the et and mph.
I did notice the johnson lifters $$$$$$
Could we see a turbo 5.3 2016 camaro SS vs turbo 5.3 2016 camaro SS grudge race in Indiana???
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 10-14-2020, 03:12 PM   #8
parish8
Drives: 17 SS a8
Different dyno but I am pretty sure the stock motor was over 700rwhp at 11psi. I will look for some graphs.
Old 10-14-2020, 03:15 PM   #9
parish8
Drives: 17 SS a8
What I am seeing is 770hp at 11psi. Pretty big bump at lower boost.
Old 10-14-2020, 03:20 PM   #10
parish8
Drives: 17 SS a8
Yeah. Doing some btr springs shimmed properly. Johnson lifters and 3/8” pushrods. Not cheap but not crazy money either. If this thing wants to rev I want it to rev.
I will post up some specific part numbers just in case this thing runs good and someone wants to copy my parts. The cam is kinda big. I will find those specs too.
Old 10-14-2020, 03:24 PM   #11
toohighpsi
Drives: 2015 C7 Z06 M7
Cool Swap!
Greg's statement would be left coast true, I've seen quite a lot of Gen V turbo trucks out here. Great little motor, just use your 6.2 fuel system components, they have smaller DI injectors than the LT1 engines (same HP pump).
Mike
www.toohighpsi.com
2015 Corvette Z06 M7
2021 Porsche GT4 M6
2023 Corvette Z51
Old 10-14-2020, 03:33 PM   #12
parish8
Drives: 17 SS a8
Originally Posted by toohighpsi View Post
Cool Swap!
Ahh, didn’t think of that. There should be some decent data out there all ready then.
Old 10-14-2020, 05:52 PM   #13
ZO6Ted
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
https://www.performancetrucks.net/fo...7/#post5421501
Wanted to add to this got a moment. It's a long thread but this is what I remember. 2wd 14 Silverado, 5.3 DI started with a PC and ended putting down 700 with cam and headers. Eventually ran a 10.9x with that. His buddy did the same with a 2.9 Whipple at 714 wheel. Allen took off the PC and did this turbo stock sbe. Said it was a bit lazy so he was going smaller iirc.
ZO6Ted is offline   Reply With Quote
Old 10-14-2020, 06:32 PM   #14
gtfoxy
His build thread is one of the main reasons I got into Gen 6 Camaros. No homo.
LOL. Im going easy tonight. A couple beers maybe. The wife has been giving me the look all day, so...
I figure it’s going to be down on power, to a point, all depends on where flow ends up on efficiency as to ultimately how much
I’m interested to see your intake set-up.
30deg cooler MAT than inlet is yuuuge at roughly 2x atmospheric.
