12-28-2017, 10:36 AM | #1 |
Drives: SS 6 speed of course Join Date: Jan 2016
Zl1 half shafts and drive shaft on SS
I was looking at the GM race parts and they clearly list ZL1 type half shafts for the SS:
For racers looking for halfshafts capable of carrying up to 5,000 lb.-ft. of torque on each side, round after round. This system was designed for Camaro SS drag racers and includes both right and left halfshafts, washer and bolt assemblies, hub nuts, and replacement exhaust gasket and clamp for a bolt-on and race solution. PART NO. 84398126 https://www.chevrolet.com/performanc...maro/drag-race With increased power and torque, seasoned Camaro drag racers know they need heavy-duty driveline equipment to put the power to the ground, round after round. Capable of carrying up to 4,000 lbs.-ft. of torque, this system ships complete with the front flex coupler nuts and bolts, center bearings bolts, rear flex coupler nuts and bolts, the complete ZL1 propeller shaft assembly, and replacement exhaust gasket and clamp for a bolt-on drag strip solution. PART NO. 84398125 but the prop shaft it seems to be a stock ZL1 piece! Also it does not list auto or manual. do all the v8 share the same length shaft? If so I wonder why does Drive Shaft Shop and GForce list different driveshafts for the M6 vs auto?
12-28-2017, 11:31 AM | #2 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
I’m also wondering the same thing, subbed
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
12-29-2017, 10:35 PM | #3 |
Drives: Summit white 1le ss Join Date: Feb 2017
I believe for 2100 you can get dss for all 3 pieces which might be a better buy for a few hundred more
09-02-2020, 08:55 PM | #4 |
I put a Zl1-1le shaft on my SS, it was a direct bolt-on.
09-03-2020, 06:50 AM | #5 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Is the ZLE shaft different than the standard ﹰZﹰL1 part?
Baby Blue
09-03-2020, 11:04 AM | #6 |
pretty sure the 1LE part was to make sure it was a M6 drive shaft since the A10 was not a option at the time for the Zl1 1le. Now you would want to make sure it is specified as a M6 or A10 drive shaft or at least the year.
2016 NFG 1SS A8
10-03-2020, 12:46 PM | #7 |
Drives: 2018 Camaro SS 1LE Join Date: Jan 2020
Is there a difference between a straight ZL1 shaft and an SS-1LE shaft?...
10-03-2020, 06:33 PM | #8 |
pretty sure the only difference is between automatics and manuals.
2016 NFG 1SS A8
