Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 03-19-2019, 08:42 AM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
Now available from SCP: Camaro 2-Color Trunk Blackout
2016-2019 Camaro 2-Color Trunk Blackout
If you are looking for a quick and easy way to add some color to your new Camaro this 2016-2019 Camaro 2 Color Trunk Blackout is just what you need. This stripe kit is manufactured from the highest quality materials available using vinyl from leading manufacturers like 3M, Hexis, KPMF, and Avery. We select the vinyl-based on color samples and what is most accurate for your Camaro.
All of our Camaro stripe kits use an air release backing. This allows for an accurate installation. All of the vinyl we use is also UV protectant and comes with a pressure sensitive adhesive for a quick installation and a long life.
These kits are custom made and ship within 1 business day. Since our stripe kits are custom made they are non-returnable.
In addition to this 2 Color Trunk Blackout kit, we also sell hundreds of other stripes and designs ranging from hood stripes, side body stripes, racing stripes, fender hash stripes, door and rocker stripes, hood vent inserts, side scoop inserts and more.
Similar to our 1 color 2016-19 Camaro trunk blackout except with a pinstripe in a different color at the top edge. The graphic is ready to install when you receive it, we install the pinstripe before we ship it. This pre-cut vinyl section is designed to cover the area between the tail lights. Includes two sections (one with an emblem cut out and one without). Requires no trimming for install. Available for all 2016-19 Camaros.
Click here to order: 2016-2019 Camaro 2-Color Trunk Blackout
southerncarparts is offline   Reply With Quote
Old 04-08-2023, 05:23 AM   #2
southerncarparts
Thank You for shopping at https://www.southerncarparts.com/201...-blackout.html
