Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 08-05-2016, 09:04 AM   #1
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
Custom Painted 6th Generation Camaro Underhood Parts From RPI Designs
Custom Painted 6th Generation Camaro Underhood Parts From RPI Designs For July
2016 Camaro 6th Generation Custom Painted V6 Engine Cover $275.49 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro a new look. Our 2016 Camaro painted V6 engine covers are a great way to add some pop to your Camaro's hood. We buy brand new GM engine covers, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. You will not find a nicer finish on a 6th Gen Camaro V6 Engine Cover.
Because these items are custom painted to order we do ask for additional time from order date to ship date.
This engine cover is painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
These V6 Engine Covers is available in two finishes:
Standard, which has a slight texture, as shown
Smoothie, which is a glass-like finish, no texture
http://www.rpidesigns.com/shop/item....over-two-tone/
2016 Camaro 6th Generation Custom Painted V6 Engine Cover $189.99 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro a new look. Our 2016 Camaro painted V6 engine covers are a great way to add some pop to your Camaro's hood. We buy brand new GM engine covers, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. You will not find a nicer finish on a 6th Gen Camaro V6 Engine Cover. Please select the color you'd like below, the main photo is shown in Red Hot.
http://www.rpidesigns.com/shop/item....-engine-cover/
2016 Camaro Custom Painted Engine Radiator Shroud $132.99 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro some attention with this custom painted engine radiator shroud. We use original GM shrouds, sand them smooth and finish them in our glassy smooth painted finish. Each 6th Generation Camaro radiator shroud comes in your choice of exterior body colors as well as hydro carbon fiber.
Because these radiator shrouds are custom painted to order we do ask for additional time as stated on the top of this page.
https://www.rpidesigns.com/shop/item...diator-shroud/
2016 6th Generation Camaro Custom Painted Engine Fuel Rail Covers Overlays $199.49 with code PHIL5 at checkout
Save some money and save some time with RPI's new 2016 Camaro Fuel Rail Cover Overlays. These overlays are exactly as the name implies. They are ABS plastic covers that attach directly to top of your factory fuel rail covers. These overlays come in any 6th Generation Camaro color, with custom lettering of your choosing.
Because these fuel rail covers are custom painted to order we do ask for additional time from order date to ship date.
These 6th Gen Camaro fuel rail covers are ABS plastic overlays and painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....vers-overlays/
2016 6th Generation Camaro Custom Painted Engine Plenum Cover Overlay $185.25 with code PHIL5 at checkout
Set your 2016 6th generation Camaro apart from the crowd. Our SS custom painted plenum cover comes with a glassy smooth finish. This plenum cover is an overlay that attaches directly over top of your factory piece. Because this plenum cover is custom painted to order we do ask for additional time from order date to ship date.
This plenum cover is made and painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....cover-overlay/
2016 6th Generation Camaro Custom Painted Engine Plenum Cover OEM $246.05 with code PHIL5 at checkout
Set your 2016 6th generation Camaro apart from the crowd. Our SS custom painted plenum cover is available in a texture. This plenum cover is a direct replacement GM piece, you'll need to remove yours and replace it with this one. Because this plenum is custom painted to order we do ask for additional time from order date to ship date.
This plenum cover is OEM GM and painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....num-cover-oem/
2016 6th Generation Camaro Custom Painted Engine Fuel Rail Covers $265.05 with code PHIL5 at checkout
Set your 2016 6th generation Camaro apart from the crowd. Our SS custom painted fuel rail covers are available in a textured finish or hand sanded to a SMOOTHIE finish and come pre-painted in any 2016 Camaro body color. We also hand paint the CAMARO letterings on each set of 2016 Camaro fuel rail engine covers. Because these fuel rail covers are custom painted to order we do ask for additional time from order date to ship date.
These 6th Gen Camaro fuel rail covers are OEM GM and painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....l-rail-covers/
2016 Camaro 6th Generation Custom Painted Engine Strut Braces Set $189.99 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro a new look. Our 2016 Camaro strut braces are a great way to add some pop to your Camaro's hood. We buy brand new GM engine strut braces, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. You will not find a nicer finish on a set of 6th Gen strut braces for your 6th Generation Camaro. Sold as a set, one left and one right brace.
This set of strut braces are painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....ut-braces-set/
2016 Camaro 6th Generation Custom Painted Engine Dipstick - Available for Turbo, V6 and SS V8 $47.49 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro a new look. Our 2016 Camaro hood struts are a great way to add some pop to your Camaro's hood. We buy brand new GM oil dipsticks, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. You will not find a nicer finish on a 6th Gen Camaro oil dipstick. These are available for 4cyl Turbo, V6 and V8 SS. Please select your model below.
This dipstick is painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....gine-dipstick/
2016 Camaro 6th Generation Custom Painted Engine Caps $94.99 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro a new look. Our 2016 Camaro engine caps are a great way to add some pop to your Camaro's hood. We buy brand new GM engine caps, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. You will not find a nicer finish on a 6th Gen Camaro engine caps. These are available for 4cyl Turbo, V6 and V8 SS. Please select your model below.
This set of engine caps is painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....l-engine-caps/
2016 Camaro 6th Generation Custom Painted Hood Struts Set $66.49 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro a new look. Our 2016 Camaro hood struts are a great way to add some pop to your Camaro's hood. We buy brand new GM Hood Struts, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. You will not find a nicer finish on a set of 6th Gen strut braces for your 6th Generation Camaro. Sold as a set, one left and one right strut.
This set of struts is painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
Want to make your 6th Gen Camaro even more unique? We take these painted struts a step further. You can add your own custom text/phrase. We will cut vinyl and place your custom text on the outside of each strut....This way when a spectator at a show comes up from the side of your car they will see the statement your making right away! Please choose your lettering color and wording.
http://www.rpidesigns.com/shop/item....od-struts-set/
2016 2017 6th Gen Camaro Billet Aluminum Exact Fit Custom Painted and Etched Engine Caps Package
RPI Designs has recently just purchased Nakid Parts Billet Engine Caps product line and we are now manufacturing these 6th Generation Camaro Painted Billet Aluminum Engine Caps in-house. We wanted to make sure these products live up to the reputation of the original Nakid Parts so Josh and Tim from RPI Designs went out to Nakid Parts and were taught the ways of making these parts. Many of you in the Corvette hobby know that Ed created the best looking, best fitting and best quality engine caps available for the 6th Generation Camaro. With Ed's original design and RPI's manpower, we are excited to bring you the original finishes and a few new finishes to these same great engine caps. We purchased the original tooling so that each cap is exactly the same as the original. We want to make sure the quality and the tradition will carry on and now they are available from RPI Designs!!!
We also want to make sure you are aware of the following:
- We are the sole manufacturer of these caps.
- These are HIGH-Quality caps that you can see from the thickness and the weight of the caps.
- The fitment is better than any other cap on the market, just check out the picture comparing our caps to other ones.
This kit includes covers for:
Brake Reservoir Cover
Coolant Tank
Washer Tank
Oil Fill
These engine caps highlights include:
•Billet Aluminum (Heavy)
•Made 100% in the USA
•Exact Pressure Fit (put on without tape or choose to use tape if you'd like)
•Available in all body colors
•Available with custom etchings and lettering colors
Please note: As these are made to order we do ask you to allow us additional time from order date to ship date. There are a lot of order option for these caps, please make sure you go through all these options before you submit your order.
Item # 16-PD1600 Use coupon code PHIL5 online or by phone and save 5% off the listed website price!!!
Website Link : http://www.rpidesigns.com/shop/item....t-engine-caps/
Camaro 6 Forum Members Save With Code PHIL5 At Checkout
RPI Designs is offline   Reply With Quote
Old 11-02-2019, 07:02 AM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
Thank you for the orders!
RPIDon is offline   Reply With Quote
Old 12-11-2020, 09:15 AM   #3
RPIDon
RPIDon's Avatar
Drives: Camaro
