Old 08-10-2019, 02:59 PM   #85
funked1
funked1's Avatar
Drives: '23 Hyundai Kona N, '24 VW GTI
Originally Posted by mulage View Post
anyone found where to tap into 2019 camaro for hardwire?
I tried. Removed the panel above the rear view. Completely different connectors and wire colors from the OP's 2016 guide. I found ground and 12v on the airbag connector using a DMM. I inserted my RJ11 taps and verified 12v and ground on the correct RJ11 pins. Uniden R3 would not turn on. So I think there is some kind of current limiting on the airbag light connector now. Airbag light works fine still so it wasn't a fuse. I am looking into alternate tap locations and/or aftermarket options. For now I am just using the cigarette lighter.
funked1 is offline   Reply With Quote
Old 08-10-2019, 10:01 PM   #86
honus03
Drives: 1979 Camaro. 2016 2LT/RS V6
Gen5Diy makes a harness that is pretty much just plug and play for the R3 and Camaro.
honus03 is offline   Reply With Quote
Old 08-12-2019, 01:54 PM   #87
funked1
funked1's Avatar
Thanks, I will be getting that. I probably could figure it out myself but I have already spent more time than it was worth. Just spend the money, dummy.
Old 01-12-2020, 11:15 PM   #88
Iceman2k
Iceman2k's Avatar
Drives: 2019 Chevrolet Camaro 2SS
So did you get the gen5diy kit and did it work ok for your 19? I have a 19 2SS with the rear view camera and looking to make sure their kit will work. Also, did you purchase a Blendmount for yours?
Iceman2k is offline   Reply With Quote
Old 01-13-2020, 04:58 AM   #89
cmfhsu
Drives: 2019 2SS 1LE
I have the '19 kit. It comes with ~6 feet of extra cable because gen5diy now pulls from the HVAC module in the passenger footwell. They give good instructions on how to route it, but I do wish we could pull power from the onstar module like we did before.
Very clean once you get it installed, but pretty fiddly to get right at first.
cmfhsu is offline   Reply With Quote
Old 01-20-2020, 01:40 PM   #90
subgraphic
Drives: '16 2SS
Very good write up- Thanks!
I just followed it to do mine and it worked perfectly.
Couple of things: I didn't unplug all the clips, just the white one you used from the back. I just let the panel hang there.
I also used a wiretap line that came with my mirror mount (just like the one in your post)
It was too short to run under the headliner, so I just let it exit from the back of the panel and it still looks clean and hangs in a perfect spot when not plugged in.
subgraphic is offline   Reply With Quote
Old 08-18-2020, 06:24 PM   #91
robertd33
Drives: 2018 2ss redline
anybody know which wires it taps into?
could save some upside-down neck strain.
edit:
nevermind, already taken care of:
https://www.camaro6.com/forums/showthread.php?t=580196
robertd33 is offline   Reply With Quote
Old 06-15-2021, 06:39 AM   #92
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
robertd33 I posted the same question on your thread following the link above.
I need to connect an accessory to the tuner module which is located in the passenger footwell, in the panel right behind the glove box. This accessory needs switched power and I am looking for a switched power source in the passenger footwell area. The purple/white wire that you picked for your installation, as described in your writeup, would be ideal for that. Can this wire be used as a source of switched power?
Old 06-22-2021, 01:11 PM   #93
MakCamaro
Makis
MakCamaro's Avatar
That's OK, I will tap into the purple wire that goes onto the cigarette lighter power port under the center console, as described in this post:
https://www.camaro6.com/forums/showp...6&postcount=64
Old 07-19-2021, 10:49 PM   #94
dbs1
Drives: 2017 ZL1
As a note, I recently got my 17 ZL1 back from the body shop who had to pull the headliner down to chased an issue with the airbag and got it back with my V1 laying in the passenger seat so I had to go back and redo the install.
After a few tries with no power I discovered the purple wire had no power but the brown/white did. Just in the event others were having issues getting your radar detector powered up...
dbs1 is offline   Reply With Quote
Old 12-04-2021, 11:36 PM   #95
EastHoosier
Drives: 2022 ZL1, 2018 F150 5.0
As mentioned in some other posts, the 22 models won't give you the appropriate power from all of the terminals behind the light/airbag plate.
I tried tapping the little light in the middle that is always on when the car is on, and it gave the radar detector enough power to buzz, but that was it.
Before I give up and do something under the glove box or from the cig lighter I was going to try the terminals under the plastic cover in front of the glove box (if that makes sense).
I couldn't get the connector to pop out, so i was wondering if anyone has tried this, and should I even waste my time? And, how do i get this connector to come off?
EastHoosier is offline   Reply With Quote
Old 12-05-2021, 03:10 AM   #96
MakCamaro
Makis
MakCamaro's Avatar
Don't waste your time like I did. Tap into the purple wire that goes onto the cigarette lighter power port under the center console. This is the safest way to do it and it will give you the power that you need.
Old 12-05-2021, 10:38 AM   #97
NC_Summit_1LE
NC_Summit_1LE's Avatar
Drives: '19 ZLE Summit White 6spd
So I tapped into the always on light in the overhead console of my 19 ZLE and it is powering my R3 just fine. Once you shut the car off and lock it, radar turns off.
NC_Summit_1LE is offline   Reply With Quote
Old 12-07-2021, 08:12 PM   #98
NC_Summit_1LE
I admit defeat. I'm back to the lighter plug. All I get now is a buzz and no power. Guess it's time to run some longer wires.
