10-04-2015, 11:33 AM | #1 |
Drives: 2011 1LT Join Date: Mar 2012
Separation issues... can you help me?
The attached image shows two hard plastic drinking cups. Each is about eight inches tall, and the two cups are nested. They were washed, then dried, and placed in to the cup cabinet.
However, NOW they refuse to separate. I have tugged and pulled and cursed. I have tried squeezing the inside cup's mouth into one "oval," while squeezing the other in a perpendicular oval. I tried filling the inner one with ice water, while simultaneously resting the outer one in hot water. I introduced oil in between their surfaces. I tried introducing water. Now, there only seems to be a vacuum seal that has been produced by the introduction of liquids. I have used sharp metal tools to attempt prying and lifting, "walking" the inner cup out of its prison. None of these have worked. Of course, I could crush/ destroy one cup in order to free the other... that's no fun. Any ideas on how to separate these two, and finish with two still- usable cups? |
10-04-2015, 11:52 AM | #2 |
Drives: 2014 2SS/RS Camaro Join Date: Dec 2014
Sounds like suction is the problem. They were maybe fresh out of the dishwasher (hot) when they were put together and now they are stuck? Try sticking them in the freezer for a few hours and see if that works. If not, stick em back in the dishwasher then try to take them apart when they are hot.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH |
10-04-2015, 04:42 PM | #3 |
Drives: 2014 2SS/RS - SIM Join Date: Apr 2014
A shotgun would separate them, that would be fun!
10-04-2015, 05:10 PM | #4 |
Moderator.ca
When warm, moist air cools it exerts less pressure (ie, causes a partial vacuum). Dunk them in some hot water for a while and the trapped air should get back to normal pressure.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
10-04-2015, 05:19 PM | #5 |
Drives: 2010 Camaro 2SS/RS LS3 Join Date: Oct 2013
Drill a hole in the bottom one that will break the vacuum and when you want to use just place it inside the cup without the hole drilled in the bottom
Hurst Short Throw Shifter, K&N CAI, SRP Racing Pedals, GM Performance Exhaust, GM GFX Package
Lakewood Strut Tower Brace, JBA Shorty Headers, JBA 8 MM Wires, Airaid TB Spacer, Phastek CAI Scoop, Washer Bottle Relocation Kit, Stainlees Steel Brake Lines, Brake Performance Slotted and Drilled Rotors, BMR Tunnel Brace, BMR Trailing Arms, BMR Subframe Connectors, Borla ATAK Muffelers, Z28 Wickerbill Spoiler, VTC, Bow Tie Delete, BMR Adjustable Front Swaybar, BMR End Link Kit, BMR Extreme Rear Anti-Roll Kit, Diablo I1000 "InTune" |
10-04-2015, 10:09 PM | #6 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
Hold the outer one while tapping the inner one one the edge of your counter.
10-04-2015, 10:59 PM | #7 |
Drives: 2018 1SS M6 Join Date: Nov 2014
This one is easy. Run the bottom of the cup under hot running water. Just the bottom, not the whole thing. This will cause the air in the gap to expand will almost push the cups apart. It may take about a full minute or so once the water is hot.
I work in a restaurant and this happens all the time. |
10-05-2015, 03:28 AM | #8 | |
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jul 2014
10-05-2015, 06:48 AM | #9 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
My guess is that your sister-in-law, stilled pissed over the beer tasting contest, has super-glued them together.
10-05-2015, 10:17 AM | #10 | |
Okay, I have them separated, but I had to go to extremes. I tried most of your suggestions here, but even hot and cold water tricks just weren't cutting it. What DID finally work was REALLY hot and REALLY cold: I filled the inner cup with ice water, and placed the pair into a pot of boiling water. After a few minutes--- with the ice still intact--- I was able to "walk" the inner cup out by prying with a sharp knife tip. Thanks for the help, my friends! |
10-05-2015, 10:57 AM | #11 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
Are these really old expensive cups or a family heirloom or were you just trying a non-dangerous Mythbusters experiment?
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
10-05-2015, 11:05 AM | #12 |
10-05-2015, 12:00 PM | #13 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
Surprised nobody mentioned WD40
10-05-2015, 12:07 PM | #14 | |
Drives: 2015 SW 1SS/RS 1LE Join Date: Mar 2015
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
