Old 09-24-2018, 08:13 PM   #1
TDS
TDS's Avatar
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10
**Price Reduced** FS: 2017 ZL1 A10
2017 Camaro ZL1 10 speed automatic transmission with 10,xxx miles on it.
The car will come with all factory parts (except stock rims and tires) and everything listed below. In addition, it will come with its own laptop and HP Tuners for swapping tunes. I only use the Meth injection at the Dragstrip, so it runs around on the street tune and 92 octane most of the time 642WHP, Methanol tune bumps it up to 673WHP (last time it was on the dyno) since then Kaizenspeed has done several tweaks on the tune, we have also added a tune with 110 octane race gas with the methanol, butt dyno says over 700WHP, on that tune she ran a 10.5 and sits a top of the bolt on only fast list. The car drives like stock on the street still averaging 20 miles per gallon on the highway (If you don’t pass aggressively) The car is all around in good shape but is 2 years old, not going to sit here and tell you it is perfect. The car was parked inside its whole life. I am sure there are somethings that are being forgot, but you get the idea. I am sure several people will ask the question of why I am selling the car, here is why. I love this car, it was always a dream to custom order a car, but at age 42 decided to switch careers, could not see myself doing what I was doing for another 20 years. With my previous employer I had a truck allowance which is now gone. So, with the loss of the allowance and the decrease in salary for taking on a new challenge, it is just not feasible to keep the car. But believe me, when the salary gets back to what I am accustom too I will be back at Chevy ordering another car.
Car as it was ordered with these option:
Performance data and video recorder, Chevrolet Mylink audio System w/navigation & 8” touchscreen, Black Metallic center strip, Premium floor mats, Battery protection package, Wheel Locks, Cargo net.
Here is a list of accessories and performance parts installed on the car.
Exterior: Tinted windows 32%, Blacked out marker lights, Clear/Black GM rear tail lights & 1LE third brake light
Interior: Dynamat in key areas to stop metal vibration, then a layer of ¼ inch foam and then a layer of mass loaded vinyl. This was done on every square inch of the cars floors (cockpit & trunk) The front doors and rear wheel wells received Dnyamat and foam. It reduced road noise my over 20db. If you have been in a ZL1 the road noise is horrible, not in this car. It did add about a 100 pounds of weight if you were curious, but don’t worry there is plenty of horsepower to make up for it. There is also 3 gauges in the car, two in a dual pod-AEM Air/Fuel & AEM pressure gauge to monitor methanol injection when in that tune, the other gauge is mounted in a custom pod in the driver's side air vent, it controls the methanol and doubles as a boost gauge. Also, a Passport IX radar detector that I will through in with the deal.
Wheels and tires: Ace Alloy AFF02 20” custom wheels, Tires are Nitto NT555 G2. Also swapped out stock brake pads with Carbotech brake pads, way less dust.
Performance Parts: RotoFab dry filter C.A.I., Ported Throttle Body, Kook’s 2” headers with cat delete, Borla 3” type S cat back exhaust with NPP valves, Innovators West 9.10” lower pulley, Gates HD Belt, NGK spark plugs, Fire Core wires, Elite Engineering E2-X catch can, NX LT4 supercharger lid, Snow Performance 2.5-gallon trunk mounted methanol tank with custom brackets w/150 psi pump and braided lines, ProMeth direct port injection kit with 8 nozzles, Coolingmist progressive control in custom vent pod, AEM air/fuel gauge with Bosch wide band sensor, AEM pressure gauge, HP Tuners Pro, Plus several thousand dollars in labor and tuning.
$59,800.00
Let me know if you have any questions,
Thanks for looking, Travis
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats
Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer
TDS is offline   Reply With Quote
Old 09-24-2018, 09:40 PM   #2
RandRZL1
RandRZL1's Avatar
Drives: 2018 ZL1
Wow best of luck to you! Wish I were able to learn more from your efforts!
RandRZL1 is offline   Reply With Quote
Old 09-25-2018, 05:33 AM   #3
Akura
Akura's Avatar
Drives: ´18 ZL1 A10 Red Hot 😍
Good luck in your new life!
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
Akura is offline   Reply With Quote
Old 09-25-2018, 08:15 AM   #4
GP86
GP86's Avatar
Drives: 2017 2SS
Good luck on your future endeavors! I hope the next project is even more badass than this one!
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
GP86 is offline   Reply With Quote
Old 09-25-2018, 09:05 AM   #5
Hell of a deal for someone!!
Old 09-25-2018, 09:27 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Nice car!! GLWS
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 09-25-2018, 09:36 AM   #7
chrest
chrest's Avatar
Drives: 2017 Camaro 2SS
sad to see!
I can vouch for this car. not a corner cut.
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 09-25-2018, 10:17 AM   #8
TDS
TDS's Avatar
Thank you all for the support!
Travis
Old 09-28-2018, 10:22 AM   #9
Gonasurvive
Gonasurvive's Avatar
Drives: 17 ZL1 MBM M6
I will also vouch for this car and TDS.
If you are still in the area, can't wait to see your next project!
Gonasurvive is offline   Reply With Quote
Old 09-28-2018, 03:23 PM   #10
TDS
TDS's Avatar
Thank you. I will still be in the same area.
Travis
Old 10-02-2018, 07:19 AM   #11
TDS
TDS's Avatar
Good morning everyone. I reduced the price to help the car sell, Seems like such a shame to take a nicely built car and return it to stock just to sell it or trade it in. Willing to help ship if necessary and live only 30 minutes from Portland International Airport if you would like to come see it.
Have a good day
Travis
Travis
Old 10-07-2018, 06:35 PM   #12
TDS
TDS's Avatar
Sunday night bump!
Travis
Old 10-11-2018, 12:47 PM   #13
TDS
TDS's Avatar
Going to start pulling the parts off the car to sell individually, I will repost the car when it is basically back to stock.
Travis
