Roto-Fab
Old 01-11-2024, 09:47 PM   #85
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I definitely can feel more power from when I installed the Ported Rod Mod intake. I can now feel some tire spin on the 2-3 shift at WOT, which I never had before...My trans is a mess...Not really, just sloppier than I would like. Very inconsistent. I have 172k on the trans, so I can't ask for much. I will state that some BIG changes are coming to my car and trans. Haven't nailed down all details yet.
Only issue is that I am noticing she is running VERY LEAN on idle now, since after the ported rod mod install. I don't have a wideband, but I do monitor STFTs, and at idle I am usually between +15 - 20%. I did not retune after install. WOT pulls seem to be more in normal range, but as I said, I'm only monitoring trims, so accuracy isn't great. Confirmed no vacuum leaks, at least as far as I can tell. Idle speed is perfect. I will add I try to stay off of her too heavy since I noticed the lean issue. Lucky if I drive it 50 miles a month right now.
InFiD3ViL is offline   Reply With Quote
Old 01-16-2024, 07:26 AM   #86
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Some additional trim at idle is not unexpected, and one of the most "affected" areas by airflow changes through the engine. The beauty of a closed loop fueling system is that you can make some minor airflow changes like that without taking things too far out of calibration. What you'd ideal monitor to have an idea on where the AFR has gone would be the long term fuel trim PLUS the short term fuel trim (LTFT+STFT) as that's a wholistic value on what sort of trimming the ECM is doing. STFT alone doesn't tell the whole story, that's a very fast changing value. When it trends far enough off center for long enough, the LTFT will step in and make a correction that will bring it closer to center. The ECM learns and remembers those LTFT corrections, which has the effect of bringing those STFT in line quickly.
Of course, what I just described above depends on the tuner still using LTFT - which not all do. Many will remove the LTFT completely, and operate just with STFT. This is done because LTFT has the ability to impact the AFR under power enrichment (full power). It also adds a small amount of complexity to the tuning process. It's a bit of a debated topic, with good logic and support for either approach.
All that to say, what you're seeing sounds fine. Enjoy the new power. Really feel it come on in the 3500-4500rpm range? That's where I noticed the rod mod added the most when I had one. It's across the whole curve, but we've seen as much as 35ft/lbs increase in torque through that particular range, really stand the curve up earlier and stronger!
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 01-31-2024, 06:34 PM   #87
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
[QUOTE=camguynj;11360905]Thanks Andrew, good to know.
Update - I did wind up replacing the gaskets on the ported IM from GPI as two of them appeared to be compressed flat even with port wall. I also lined the IM with ThermoTec 13575 aluminized heat barrier.
FWIW I noticed that after a faint dusting of snow the snow was still on the hood cowl over the IM after the car was off a few hrs and nowhere else. I’m assuming the IM temp was lower than elsewhere in the engine bay due to the heat barrier I also have the IM clam shell removed.
camguynj is offline   Reply With Quote
Old 02-01-2024, 08:56 AM   #88
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
I have this rod mod / ported intake in my cart for a while now. I really want to do it before my track day in April. My only concern is that i dont necessarily LOVE my trifecta tune but it has served its purpose up until now which was keeping my SES light off for inspection. If im gonna do this, id like to get retuned but not sure what route I want to go for that. Dyno tuning in my area is either non existent or when they see my car, they want like 1000 bucks to tune it. My buddy with a 5.0 just got his headers installed and dyno tuned for 800. Unfortunately, where he went, they wont touch a GM product lol
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads
Arogg is offline   Reply With Quote
Old 02-01-2024, 09:23 AM   #89
camguynj
camguynj's Avatar
I had the same concern about needing a retune on my cammed n/a LS3 so I asked GPI. They said no as the ported rod mod really doesn’t change IM pressure it just delivers air at an increased velocity constantly throughout the rpm range.
Old 02-01-2024, 01:50 PM   #90
Arogg
Arogg's Avatar
Yeah, i asked the same. In general, i really just want a better tune lol. I might just buy the intake now and worry about a tune when I do more work. Its affordable enough but house hunting with a kid on the way has SERIOUSLY put a dent into mod money
Old 02-12-2024, 05:28 PM   #91
Leadsled
Leadsled's Avatar
Drives: 2010 Camaro SS 6MT
My original tune for my car was about 650-700 the first go around. (Cam setup) My re-tune was for gutting the cats and ported TB. The second time around I was only charged $200 which gave me about 4 pulls.
My point being the first tune should be the most expensive tune until you add something like power adders (N02/turbo/SC). No need to punish you for trying to have more fun.
I drive 3hrs one way to my tuner also
TSP 229/244 .629"/615" CAM w/ a bunch of goodies 465whp/443tq tuned by MayhemMotorsports-NC
Leadsled is offline   Reply With Quote
Old 03-14-2024, 03:10 PM   #92
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
So I finally got around to it.
Installation went surprisingly smoothly.
The bigger problem was finding the order and torque of the bolts.
I was curious about the difference and it came right after the first start.
I had driven the car with the OEM intake all day before so I had a starting point for comparison.
The car was right from idling - stronger, a much bigger pull was felt.
I have to admit that the guys from GPI did a very good job.
Now I will adjust the tune and it will be absolutely perfect.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 03-14-2024, 03:17 PM   #93
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Is Steve going to adjust your tune? Let me know if you notice difference after re tune, I didn't retune after the swap.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 03-14-2024, 03:52 PM   #94
George-CZ
George-CZ's Avatar
Yeah, we agreed to do it.
He sent me the values he wants to record and now it's just a matter of my free time that I have to take to do it.
Do you want a private message or is it enough here in the thread?
Old 03-14-2024, 04:20 PM   #95
Joe.G
Joe.G's Avatar
Here is fine, I was just curious if it's worth it, Steve told me not really needed.
SCT X4 Dynosteve,
Old 03-14-2024, 04:47 PM   #96
George-CZ
George-CZ's Avatar
Thumbs up
I directly asked him for it.
Maybe it won't be necessary.
But at least the control can be done.
O.K. I'll keep you informed.
Old 03-14-2024, 09:21 PM   #97
camguynj
camguynj's Avatar
GPI told me a retune is not needed as the ported rod mod doesn’t change IM pressure, it just provides an improved constant air flow velocity throughout the rpm range
Old 03-30-2024, 08:18 PM   #98
Bluebagger06
Bluebagger06's Avatar
Drives: 2012 camaro ss
Im not so sure about that , I have looked at everything 5 times over and dont know why i get CEL light on my car with the ported rod mod, Its P0106,0086 codes and if you rev it up it goes into reduced power mode!! Even broke one of those pos intake bolts from taking it off and on so much, New GM gaskets, MAP sensor , have a new MAF sensor coming tomorrow , along with smoke machine to verify i dont have a leak or cracked intake, I have others telling me it needs a tune! Andrew suggested the smoke tester!
GPI Powered
Bluebagger06 is offline   Reply With Quote
