05-17-2021, 07:49 PM | #1 |
Drives: 2010/2SS/M6/440ci Join Date: Jan 2018
L.o.d performance ver.3 X1 manifold
L.o.d performance X1 manifold (version 3) throttle body option of 103 or 105mm. In stock
2010 2SS Camaro - Engine: 5.3 aluminum Re-sleeved 4.185 bore, 4 inch stroke, 12.5:1 compression, 440ci, SPS Dart pro1 ls3 heads, tsp ls7 stage 4.2 cam(too small), "billet bill" original X1 manifold, bbk 102mm, cai cold air. Exhaust: TSP 2 inch primaries, V-band merge, hooker blackheart x pipe (modified) spintech 9000 mufflers. Drivetrain: Dss 1 piece driveshaft, MGW shifter, Z28 clutch, ram aluminium flywheel. Body: ZTA spoiler, de-badged, ZL1 front bumper, 14-15 mohawk, two tone paint.
05-17-2021, 08:46 PM | #2 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Very nice. Sorry if this is common knowledge but how much higher is the center of the TB placement with this intake?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
05-17-2021, 09:16 PM | #3 |
Its approximately 2 inches higher then say a ls3 manifold. Fit is perfect on 5th gens 90%of existing cold air fit up still
05-18-2021, 04:04 AM | #4 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Any cutting needed it larger hood?
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
05-18-2021, 05:46 AM | #5 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
No cutting, fits under the strut tower brace too
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
05-18-2021, 06:48 AM | #6 |
That’s awesome
Any dyno numbers and charts comparing it to stock/high ram?
05-18-2021, 08:09 AM | #7 |
Clark beat me to it, no cowl or hood cutting. Zl1 guys will have to trim the drip tray a little. 14-15 guys have to remove the lower drip tray
05-18-2021, 08:12 AM | #8 |
Old graph from the manifold shootout at gpi. This was on a sbe ls3
05-18-2021, 08:56 AM | #9 |
Man Raf, those are just an amazing piece of equipment!! I really love mine!! Thanks. I need to give you a call soon as I am going to swap out my 92 snout still for the 103 and do the NW 103mm TB... Good to see ya back on..
05-18-2021, 09:00 AM | #10 |
Here is mine with the K&N CAI..
05-18-2021, 09:08 AM | #11 |
Think this might be my front runner option now when I go boosted
05-18-2021, 09:24 AM | #12 |
Thank you sir and I forgot yours was a 92mm you see some significant power with a 103 on the engine dyno it was around 20hp
05-18-2021, 10:44 AM | #13 |
Drives: 2010 SS L99 Join Date: Sep 2018
Raf would you put any value in having the insides of the X-1 polished?
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
05-18-2021, 10:54 AM | #14 |
Ehhhh perhaps in the most extreme cases. Max, max effort. There's plenty of material in the runners for those that want to venture into 6 bolt head territory.
