Old 11-23-2018, 05:46 PM   #1
ste1n
Drives: 2019 2SS
2019 Camaro Tow Hook Install?
I bought a 2019 2SS on Wednesday and I would like to install tow hook license plate holder that zl1 addons sells but I couldn't figure out how to remove that little part of the grill like shown in this video
Does anybody know how to do it?
Here is a picture of the grill. I don't see any way to remove it.
ste1n is offline   Reply With Quote
Old 11-23-2018, 10:24 PM   #2
DenverTaco07
DenverTaco07's Avatar
Pull / pry down from the top, just under the solid black part of grill. you will see a small pry slot if you need it but i can get mine with just fingers.
Old 11-24-2018, 08:31 PM   #3
ste1n
Drives: 2019 2SS
I checked the grill again but I couldn't find any small pry slot and I am a little afraid to pry/pull down from top.
While I was looking around I found this little tab in the grill. Could this be the spot I am looking for?
Old 11-24-2018, 09:18 PM   #4
spike2019
Drives: 2019 SS 1LE
I also have a 19 ss 1 le camaro and can not even budge the part of the grill to remove it .. WHAT IS THE SECERET TO REMOVE IT.
spike2019 is offline   Reply With Quote
Old 11-24-2018, 11:12 PM   #5
DenverTaco07
19's must have different grill...sorry, try owner's manual.
Old 11-25-2018, 12:22 AM   #6
ste1n
Drives: 2019 2SS
I think I found it. I will give this a try later.
Old 11-25-2018, 05:57 AM   #7
Silverado57
Silverado57's Avatar
Drives: 2017 Camaro SS
I'm getting this - and the license plate holder!
Kevin
Luceo Non Uro
Silverado57 is offline   Reply With Quote
Old 11-25-2018, 06:43 AM   #8
Warrior102
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Did the guy in the video install that bracket upside down, I'm not seeing how this looks any better.
Warrior102 is offline   Reply With Quote
Old 11-25-2018, 07:09 AM   #9
Silverado57
Good question. I think the real benefit is that you're not drilling the grill to put the ugly plastic plate holder on.
When we retire and move to a free state that doesn't require the front plate we can easily switch to the tow hook.
Kevin
Luceo Non Uro
Old 11-25-2018, 07:50 AM   #10
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
The front plate frame that came on my car does not drill into the bumper but rather holds on with clamps.
If you remove it, no damage or marks.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
Airfuel is offline   Reply With Quote
Old 11-25-2018, 07:58 AM   #11
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
Actually write a ticket for no front plate? Good grief...I mean I can see it being a PC stop if you're suspicious but talk about all the other crap going on that needs LE attention...
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
Old 11-25-2018, 08:19 AM   #12
Warrior102
Warrior102's Avatar
My dealer tossed it into the trunk to let me decide, I attached it with wire ties to get through inspection and then removed it. I don't see why wire ties couldn't be a permanent solution, they held well. I carry it around in the trunk and plan on talking my way out if it becomes necessary, so far no one has given a crap.
Old 12-05-2018, 04:42 PM   #13
Extrapootie
Drives: 2019 SS 1LE
If anyone was wondering, the zl1 addon license holder fits on the 2019 ss, just put mine on a few minutes ago.
Tip, when releasing the 1st clip, you want to pull up on the plastic piece of bumper. (the tow hook cover doesn't have much play up there)
Once you release the 1st clip, you then release the 2nd one which is super easy.
After the 2nd one is released, the side fins will slide out to the left.
I took some pictures just in case. Send me a pm or I can post them in this thread if anyone is interested.
Extrapootie is offline   Reply With Quote
Old 12-05-2018, 05:21 PM   #14
ste1n
Drives: 2019 2SS
I ordered it and it should be here in couple of days. Could you post the pictures please? I tried to remove it again the other day but couldn't manage it.
2019 camaro, license plate holder, tow hook
