03-30-2017, 10:55 PM | #29 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
yes there is always that risk of modding your car while in warranty and having to pay for your own repairs... this is not new information.
03-31-2017, 07:11 AM | #30 |
Drives: 2013 ZL1 M6 Convertible Join Date: Apr 2013
No one said there is no heat issue, he just said Chevy did a good job and money is better spent on other mods at my HP level. I do let my car cool down before first run, and in between 3-5 hot laps. My problem is with the launch and the 60' time. Here are 2 separate time slips. I'm #22 & #90.
Mild to Wild Switch, Roto Fab CAI, Big Gulp, Washer Relocation, Ported Throttle Body, Rough Idle Road Race Cam, Supporting Valve Train Upgrade, Dynatech Long Tube Headers Ceramic Coated and High Flow Converters, Injector Dynamics 1025 cc, 22.5%Overdrive Balancer Pulley, Fuel Pump Voltage Booster, Moroso Catch Can.
Jannetty Installed and Tuned. 675 RWHP 630 RWTQ 11.325 1/4 Mile Time @ 124.53 MPH |
03-31-2017, 07:14 AM | #31 |
709 RWHP & 677 RWTQ
Drives: 13' HPE 800 ZL1..... IOM vert, M6 Join Date: Feb 2013
My regret on my cam is that I didn't go with a more aggressive one! 657 RWHP seems like a lot until you drive it for a while and realize, I NEED MORE POWER!!!! To much is never enough!
11.34 @ 124.88
03-31-2017, 07:53 AM | #32 | |
Drives: 15 ZL1 red hot A6, 17 ZL1 Black A10 Join Date: Nov 2015
03-31-2017, 08:32 AM | #33 | |
I'll take my advise from Ted Jannetty. Thank You Very Much!
03-31-2017, 09:21 AM | #34 | |
Seconds faster? I never said I am the smartest it just doesn't make sense to me to add more horsepower and heat when you can't use the horsepower that the stock car has. Your right my car isn't stock I did do cooling mods first and will add a lot of other things behind that. Personally I would be pissed if I spent as much money as you and a lot of others have and couldn't go any faster than you are! Also Chevrolet ran there car 11.90's on stock tired and I think they said 11.7's with DR's. The fact is the cooling is deficient from the factory but it doesn't matter how big of an intercooler you get you will never get lower than ambient temperatures very best case scenario. What it does do is allow you to cool back down quicker especially if you have one with fans and set it up so you can run the pump in the staging lanes. |
03-31-2017, 10:38 AM | #35 | |
03-31-2017, 01:12 PM | #36 | |
Drives: 2014 Camaro Zl1 Tripple Black! Join Date: Nov 2014
Are you using drag radials? |
03-31-2017, 01:46 PM | #37 |
709 RWHP & 677 RWTQ
11.40's stock?! Are you staging with the rear tires? Thats impressive!
11.34 @ 124.88
03-31-2017, 01:48 PM | #38 |
Best time with Drag Radials was 11.510
Best time with Slicks & Skinnies so far is 11.325 My Drag Radials spun like crazy so I had to come out of the hole real easy to even get into the 11's. My Slicks grab so good they don't spin and my car has been bogging and nose diving. Launch control didn't work at all with Drag Radials but I'm going to try again with Slicks. My car is not the problem. The problem is the Driver, Me. BFASTNOTLAST told his secret on loading the car up at the gate by slipping the clutch with the ebrake on until the light. I plan on trying that too. It makes so much sense. I don't care, I LOVE my CAR and I've been having a BLAST trying to get into the 10's.
03-31-2017, 03:44 PM | #39 |
No sir! I just make sure the car is good and cool before I run it, and I got an automatic so any dummy can drive it! Lol. I now have an active interchiller so I can hot lap the car. I can say the car doesn't spin at all and doesn't bog when it hooks up. I don't know why a car with 200-250 more HP would bog out of the hole wether it be manual or auto. I also would think it would run more tha 2-4 more MPH on the big end.
03-31-2017, 04:11 PM | #40 | |
Drives: Z/28 Join Date: Jan 2015
2. It's entirely reversible. 3. Stuff that's entirely reversible isn't going to have a dramatic effect on value long term (if that's what you care about), as long as the car is mechanically sound and in good condition overall. I had over 100,000 miles on a C5 Z06 with a huge cam, long tubes, and head work. I installed the parts at around 30,000. I never had a single problem with the car related to the cam install. I can assure you - LS motors have been modified with huge cams and head work by thousands and thousands of people, probably amounting to millions of miles of driving. As long as the work is done right, corners aren't cut, and the cam package is spec'd correctly, you will not have issues. In the case of the LS7, you may even end up with a more reliable motor if you address the valve guide issue in the process. My Z/28 now has 5,800 miles on it - I fully intend on doing heads, cam, and long-tubes in the very near future because I bought the car for my own personal enjoyment, not to preserve it for the next guy that might get it (assuming I ever sold it). |
03-31-2017, 04:19 PM | #41 |
Gearhead
Drives: 2012 ZL1 Join Date: Jun 2014
I do not regret my cam. I do think that one should resist the temptation to go overboard with the cam on these engines. If one wants to retain stock-like driveability and durability, there is much to be said for the LS9 cam. My cam is somewhat more aggressive, and yet retains driveability that I find quite acceptable; it does fine in the drive-through or at 6800 RPM down the straights at the local road course.
File this one under "better to remain silent and be thought a fool"
2012 Chevrolet Camaro ZL1 M6 - JRE 650 RWHP kit, AFCO heat exchanger, JPSS V4 aero, Z28 wheels for the twisties and Weld big-n-littles for the dragstrip. 11.193@128.13 in 515' DA |
03-31-2017, 04:22 PM | #42 | |
