Old 03-07-2017, 11:42 PM   #1
bobbygonzalez21
Drives: 2017 Camaro Convertible (RS)
Can't Put Top Down Sometimes
Does anyone experience the dash notification that the cargo partition is down so their top can't go down? I don't remember the exact text, but I've been receiving it lately even though the partition is up.
Any idea what the error might be? (mechanical vs. technical?) Any fixes? Thank you!
bobbygonzalez21 is offline   Reply With Quote
Old 03-08-2017, 01:01 PM   #2
GroundhogSS
GroundhogSS's Avatar
Perhaps one of the snaps isn't pushed all the way on. I think is must have a magnetic switch in one of the snaps that holds the divider up. Maybe a wire is loose.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
Old 03-09-2017, 09:40 AM   #3
Donner
Drives: 2017 50th SS convertible
Hello,
If reattaching it doesn't clear it, check to make certain that there is nothing in the area beyond the partition. I had a small rag back there but the Mighty HABU knew it.
Kindest,
Donner
Donner is offline   Reply With Quote
Old 03-21-2017, 02:59 PM   #4
ncgen6vert
Drives: 2016 MBM 2SS A8 Vert
I bet you have it in "backwards" so to speak. I did that once, and it seems that the magnetic sensor, wherever it is, is just far enough away when it is flipped that it doesn't complete the circuit and thereby triggered the message. The snap has a smooth side and an unfinished side, I would say....should be smooth side out.
Look at Fig 3 on http://sandyblogs.com/techlink/?s=camaro
Chances are you have it flipped on its vertical axis...it will still snap just fine, but the magnet is now too far away.
ncgen6vert is offline   Reply With Quote
