Old 01-07-2017, 03:13 PM   #1
JBinSD
Drives: '23 LT Vert M6'16 Hyper 2SS Vert MT
Cags Eliminator on a Vert?
I bought my CAGS eliminator a couple months ago, but never had time to install. Put my car up on stands today, and it looks like the area below the transmission is completely covered by a belly-pan type structure. I don't think this is present on the coupes, has anyone installed a CAGS on a vert? Did you have access issues?
(( was using a dinky jack, so couldn't get my car very high, so wanted to make sure, since there was very little room to really see anything under the car)
Thanks
Joel
JBinSD is offline   Reply With Quote
Old 01-09-2017, 02:37 PM   #2
JBinSD
Bump, doesn't anyone have a a stick 'vert? No one did the CAGS eliminator?
I need to dig around again under the car, but there is definitely more stuff under the tranny than in the coupe.
Old 01-09-2017, 03:28 PM   #3
MattDinOC
Drives: 2017 2SS Convertible
I had my local shop do the install on my '17 vert. It was no different from on the coupes, from what I could tell. They had to reach into a pretty narrow area to get it done, but that's the same situation as on the coupe. Took 5 minutes once the car was up on the lift and we identified the right connector.
Nightfall Gray Metallic / Adrenaline Red / 6MT / NPP / MRC / 56V wheels
1100 - 07/15/16
3000 - 08/18/16 | TPW 09/05 - 08/23/16
3100 - 08/30/16 | TPW 09/12 - 08/30/16
3400 - 09/06/16 | TPW 09/05 - 09/06/16
3800 - 09/15/16 | 4200 - 09/20/16
6000 - 09/29/16 - on Camaro's 50th Birthday!
MattDinOC is offline   Reply With Quote
Old 01-09-2017, 04:18 PM   #4
JBinSD
OK, thanks for responding. In the Phastek video, it looks like its an open approach right to the connector, but I squeezed myself under the car and couldn't see it. I appreciate the info, I'll give it another try once I get it up higher, gets a little claustrophobic down there. . .
Cheers,
Joel
Old 01-09-2017, 06:44 PM   #5
RicSimonis
RicSimonis's Avatar
Drives: '17 2SS H50 Vert
I have one waiting to install (both for time and weather). Haven't had an opportunity to get under the car.
Watching and waiting...
Old 01-11-2017, 06:05 PM   #6
JBinSD
OK, found the right solenoid, and can even touch it. . . but
Failed. My fat hands can get to it, but not release the tab at the same time. I even had my wife crawl under the car and try, but she thought she'd break it, since she couldn't tell if the tab had been released.
I may have to just tuck tail and go to a shop with a lift. My shoulders barely fit under the car with the jackstands, and I"m not comfortable forcing it. Closest dealer (Weseloh in Carlsbad) wouldn't do it when I took it in for an oil change, anyone have a suggestion for a shop in north SD? I may just go to an oil-change place when they're not busy and flip 'em a $20, but I'm worried they'll break the plastic harness as well. Suggestions?
(and yeah, I'll admit wimpiness)
Old 01-12-2017, 02:06 PM   #7
MattDinOC
Bummer. :( I hate dealing with the clips that automakers use for their wiring harnesses. I just don't work with them enough to know the tricks to get them to disengage, so it's always a struggle. LOL So I didn't even attempt this myself after hearing about the difficult access.
Anyway, the best help I can offer is that, next time you're going to be up in Orange County, give Shane or Ralph at Aliso Viejo Auto Service a heads up. https://www.yelp.com/biz/aliso-viejo...ce-aliso-viejo Tell them that Matt referred you since they did this earlier on my Camaro. They did mine with no trouble (but did need to poke a screwdriver up in there), so I imagine the charge would be pretty minimal. Just call ahead to make sure that you don't show up when their lifts are occupied.
I couldn't stand that CAGS. Glad I got rid of it!
1100 - 07/15/16
Old 01-13-2017, 04:23 PM   #8
JBinSD
Thanks Matt. Funny thing is, I'm totally used to shifting around 2nd now, but just knowing its there bugs the crap outta me. I'm not much of a mechanic, but thought I could handle this simple project. I'll hit up a local guy first, but if I get pushback, I'll roll up to your guys.
Enjoy the weekend,
Joel
Old 02-14-2017, 11:49 PM   #9
c4racer
Drives: 2016 SS Convertible
I did the cags delete on my SS 2016 vert. There was no body pan under the trans on mine. No issues. Took less than 20 min. Much better. You can drive around it. But for such a cheap and easy fix why!!???
c4racer is offline   Reply With Quote
