08-01-2019, 05:05 PM | #1 |
2SS Bose Questions
I have a 2017 2SS with the Bose system. I have a set of JBL 6x9 coaxials & a set of JBL 6" separates that came out of a car we traded in. I think I also have a set 2.5-3" dash speakers also. Someone told me that I cant just replace the factory speakers with these because Bose does weird things with the wiring. Is this true & if so, what do I need to do to make this thing sound better?
08-01-2019, 08:58 PM | #2 |
Drives: 23 2SS 1LE Join Date: Feb 2019
You need to either replace ALL the speakers, or none of them. The BOSE speakers have a very low ohm rating, and if you drop replacements in, it can really change (in a bad way) the surround sound and imaging.
I just added a subwoofer. To be honest, the bose system isnt all that bad, you can turn it up and its clear, its just nothing mind blowing.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
08-02-2019, 12:06 AM | #3 | |
08-12-2019, 08:28 PM | #4 |
Been a while since I've played with a Bose car system, but generally the speakers that they run are half ohm to 1 ohm speakers designed specifically to work with their bows amplifiers.
08-13-2019, 02:45 AM | #5 | |
08-13-2019, 06:02 AM | #6 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
08-13-2019, 06:55 AM | #7 |
There are kits out there that make it easier. Plug and play then add in an amp. I cant remember who makes them though. I wont be doing this for at least another year.
08-13-2019, 07:48 AM | #8 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
There are lots of threads on this. There are 2 units, PACAudio and NAVTV.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
08-13-2019, 09:52 AM | #9 | |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
But, IMO, adding a sub without further amplifying the mods and highs won’t sound that great
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
08-13-2019, 11:13 AM | #10 |
Thanks for the technical info. What I notice is the Bose system sounds good when the car is parked, but out on the highway, it all falls apart. Instead of changing out speakers & adding amps, I’m curious if doing some serious sound deadening would be much more effective? I have a tremendous amount of road noise at highway speeds, regardless of the road surface.
08-14-2019, 12:23 PM | #11 | |
Just measure the voice coil resistance. Since all the speakers are single element, the impedance can never be lower than the VCR. Unless you are adding amplification, I would not bother changing any of the speakers. The rear deck 6x9's are pretty hard to remove/replace in the coupe due to the window rake. And the 6x9's in the doors are the main woofers anyway. I think the biggest problem with the Bose system is road noise. You've got loud run-flat tires, large resonant doors, plus the intake noise piped in via the sound tube. I also thought the system sounded so much better when the car was parked, which is why I pursued the "reduce noise" approach. |
08-14-2019, 12:50 PM | #12 |
What did you use to quiet your car down?
08-15-2019, 10:30 AM | #13 |
You are probably not going to like my answer.
New all-season tires (non run-flat) and removed the sound tube. Probably could use some sound deadening material in doors, trunk, etc. But I kinda decided it doesn't fit this car to make the cabin luxury car quiet. I can see myself in a Corvette in a few years and I am looking forward to checking out the whiz-bangery they did with noise cancellation on that Bose system. That's what they should have done with the Gen6. The development money that went into the sound tube could have been funneled into more power and tech in our Bose amplifier. |
08-15-2019, 04:40 PM | #14 |
Petro-sexual
I've used sound deadening products and depending on the content of the car prior to installing that stuff, I think you can find a fair difference in quality of the sound.
My rig was relatively well insulated to start with, but I added cheap deadener to the insides of the quarter panels and all door panels. I put a couple layers on the door panels just because I had so much. But the qualify of the sound almost made me think I changed the speakers, honestly. I mean - it's not like going from KRACO to Pioneer or something, but it was a nice gain. I also gained some more weight, too, which you'd likely do adding better speakers anyways. IMO - it's a great alternative to chopping into your car that's a good value, too.
Thread Tools | |
