06-20-2019, 01:48 PM | #29 |
Drives: '17 ZL1 Join Date: Jan 2018
Mostly when driving, especially at lower/less throttle, but just after start-up a few times as well.
Do you still have the stock TB to swap back to and see if the issue goes away? |
06-20-2019, 04:02 PM | #30 |
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound) Join Date: Feb 2019
07-03-2019, 01:24 PM | #31 |
Sell Low, Buy High
Code is back with Soler TB now and stock intake/Green Filter. Lol I don't think I'm going to figure this one out. Luckily it clears easily and seems to have zero impact on the car otherwise.
07-03-2019, 03:13 PM | #32 |
Sell Low, Buy High
Well I finally may have some insight thanks to a special friend at a dealership that pulled some info for me.
I won't directly post what was sent out of courtesy but if you need to see it if you're having a similar problem PM me. Basically either the wiring/circuit or the relay that control ECM startup is bad/flaky. The car runs and starts fine so I think mine is just borderline. The relay in question is K7 in the underhood block, part # 13455283 and it's about $30 so I ordered one to replace. I don't have the GM service tool so I can't do the full diagnostic but I did check the relay itself with a multimeter and the coil resistance is right at the top of the specified range, which is 70-110 Ohms, it read 109.6. Suspect with heat it may occasionally drift high and trigger the DTC if it's also checking that resistance somehow. Anyway, I will replace the relay and see if it fixes the intermittent issue, otherwise I think I'm finally going to have to break down and take it to the dealer as they can diagnose the circuit/wiring on the car itself using the service tool. |
07-03-2019, 04:50 PM | #33 |
Good find man, when the relay gets warm or hot the resistance will climb up and read as an open.
I had a fuel pump relay in my GTO do that same thing, causing it to go lean and I found it by accident one day, it was discolored from getting hot. |
07-03-2019, 05:07 PM | #34 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
BTW
What are your words switching from Mamo TB to Soler TB? Interested in buying Soler TB soon... Last edited by Biscuit.fr; 07-04-2019 at 02:57 AM. |
07-03-2019, 09:47 PM | #35 |
Sell Low, Buy High
07-04-2019, 02:58 AM | #36 |
07-07-2019, 05:41 PM | #37 |
Sell Low, Buy High
More interesting data. Went for a track day on Friday (mid-high 80's temps) and ran the car hard. The code popped literally on almost every restart of the car, confirming my suspicion that it was related to heat somehow.
I got the new relay in yesterday and so far so good no further codes on restarts. Hopefully that solves it and I don't have to do further digging into the circuitry to find a solution. |
07-07-2019, 06:43 PM | #38 | |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
07-07-2019, 08:13 PM | #39 |
Sell Low, Buy High
Haha I did...it was also 110Ohms...so I'm wondering if the other specs I didn't have the tools for (indicator lights etc) were bad with the old relay. Still holding my breath it will be awhile before I know for sure it's gone for good.
07-08-2019, 02:32 PM | #40 |
It could still read the same or similar resistance and be weak and heat up or over heat more quickly and pop the code.
07-13-2019, 03:26 PM | #41 |
Sell Low, Buy High
Well...car sat for a few days and popped the code again when I started it this morning so back to the drawing board.
Really really annoyed that I'm running out of options aside from taking it to the dealer so they can diagnose the circuit wiring now. If there's some kind of fault in the harness I'm having nightmares of engine removal to fix or replace the harness. |
07-13-2019, 06:04 PM | #42 | |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
this might be what you are experiencing. maybe the relay wasn't bad but your wiring harness has been compromised from rubbing on the metal and that's what's messing with your ECU. check around here, the TSB's were posted on a thread. I thought I had them saved on my phone but I don't anymore. worth a look.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
