05-28-2019, 07:13 PM | #15 |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
Stainless Works also has the NPP functional just in case you want some extra drone
05-28-2019, 08:47 PM | #16 | |
Drives: 2019 Black ZL1 M6 Join Date: May 2019
Thanks |
05-29-2019, 09:20 AM | #17 |
Drives: 2017 ZL1 Join Date: Mar 2014
05-29-2019, 09:39 AM | #18 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
I just wish Chevy could work with ARH to make the headers part of their catalog. In addition to also offering a tune that could work with the headers. Chevy could rake in millions and we would also be good from a warranty standpoint. Ugh.
#SAVETHEMANUALS
05-29-2019, 09:45 AM | #19 | |
Drives: between cars Join Date: Apr 2019
Does this require any cutting or is it truly "bolt/clamp in"? thanks |
05-29-2019, 11:44 AM | #20 |
The Corsa X Pipe with stock exhaust will require you to cut. The stock cat-back (that is, the exhaust from the primary cats out to the tips) is all one piece. You'll be bolting the Corsa X Pipe to the stock Primary cats but will have to cut the exhaust around the rear diff to clamp it to the Corsa.
12-05-2019, 12:52 PM | #21 |
Drives: 2017 1ss 1le Join Date: Sep 2015
did anyone here ever end up mating the corsa x pipe to the factory suitcase muffler?
12-05-2019, 01:41 PM | #22 |
Drives: 2020 Camaro ZL1 (A10, crush) Join Date: Jun 2019
Sorry if this is a stupid question, but what is "drone"?
2020 Camaro ZL1 Crush A10
2003 Corvette Z06 (sold for ZL1) Last edited by zl1_fan; 12-05-2019 at 02:05 PM. Reason: typo correction |
12-05-2019, 06:29 PM | #23 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
It is an unpleasant non-resonated frequency that will "pulse" the driver compartment typically around highway cruising RPMs. During long drives it will drive you crazy.
12-09-2019, 04:07 PM | #24 |
Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
I ran this set up for a month or so and I would say about a 3 louder than stock. Then I added headers, high flow cats, and resonator it's at a 5+ but sounds great. I prefer a bit of a deeper growl and I think it's perfect right before the drone would come in. Zero Drone!
