04-01-2020, 02:11 PM | #1 |
Drives: NFG Chevy Camaro 2SS Join Date: Jan 2020
Magnaflow catback replacement
Hey everyone, any help would be appreciated with the following.
I have a magnaflow comp series catback on my 16 2ss camaro without NPP. The drone is too bad for my likings. I have heard great things about MBRP. Can I remove axleback portion of mf exhausts and replace with MBRP? Both use 3inch pipes. Would this solve my drone problem? TIA |
04-01-2020, 02:24 PM | #2 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Yes, it may require a bit of fitting after the fact, but most of these exhausts are cut and hanged in about the same location. I can't comment on the drone.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
04-01-2020, 04:33 PM | #3 | |
Can’t comment on MBRP, but I switched from Magnaflow to AWE Touring and it’s amazing. Zero drone. No brainer move.
04-01-2020, 04:47 PM | #4 |
Drives: 2018 camaro ss Join Date: Aug 2013
Just buy the borla resonator problem solved and is much cheaper
2019 charger scatpack FBO 11.16@122
2020 CAMARO LT1 6spd 11.02@ 135 dragy approved |
04-01-2020, 08:56 PM | #5 |
Thanks everyone. I’m looking at installing J-pipes tomorrow. If that doesn’t work I’ll look into the other options
04-03-2020, 09:47 AM | #6 |
J-pipes will get the job done. Probably be easier then welding in another axleback.
Tags |
exhaust, magnaflow, mbrp |
