Old 03-28-2020, 04:29 PM   #1
s3rics213
Drives: 2019 1LE/ss 2014 ss/rs summit white
Lt1 to lt4 hpfp for a 2019
Update: Harness 12689504 will be a direct swap for harnesses for anyone with a 2019 trying to upgrade the hpfp to the lt4 pump.
Original:
Everyone that’s done the lt4 hpfp upgrade where the connectors the same. My connectors don’t match up. Lt4 pump 12694529 and my old pumps numbers 12697967. First pics old pump second is new.
Anyone have any idea thought these are plug and play.
2019 camaro ss
Injectors already swapped and d1x with 10 psi
2019 ss/1LE d1x, LT4 fuel System, Triple meth nozzle, ported BTR, 2” Texas speed headers, Built 377 SPDC motor, CTporting heads, TooHighPsi port system, SMG aux.
1014/800 on E55/meth
890/750 on 93/meth
Working on tuning the port system for full e.
With questions just message me here for a faster response. https://www.facebook.com/eric.willia...ibextid=LQQJ4d
s3rics213 is offline   Reply With Quote
Old 03-28-2020, 09:24 PM   #2
DorkMissile
DorkMissile's Avatar
Drives: 18 1SS 1LE HyperBlue
I believe there was a time where the plugs changed - not sure if it was 19 or 20, but you need a lt4 HPFP from the same year as your car
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
DorkMissile is offline   Reply With Quote
Old 03-28-2020, 09:56 PM   #3
s3rics213
It’s the same pn that I have I can check 2020 but for 19 the pn for lt4 and the one I have match
890/750 on 93/meth
Old 03-28-2020, 11:04 PM   #4
NickeyMatt1LE
Drives: 2017 Camaro SS 1LE
That's not an LT4 pump. That looks like the new lt2 pump with the short body. I just took an LT4 pump off a 2020 ZL1 and it looked like every other year LT4. They have the tallest housing. Taller than your stock LT1 pump. Mis-boxed maybe? Does it have that part number on the pump itself?
NickeyMatt1LE is offline   Reply With Quote
Old 03-28-2020, 11:27 PM   #5
ChrisCoffey
ChrisCoffey's Avatar
Drives: 2016 Camaro 1SS Hyper Blue Metallic
According to this and several sites selling that pump it is a lt4. It even has the same fitting. If what was previously said is true its possible to check the wire schematics for that pump connector vs the other and if indeed it is a lt4 just fabricate a wiring harness for it with appropriate connectors.
GENUINE GM PARTS 12694529 - GEN V LT4 HIGH PRESSURE FUEL PUMP
(0) Reviews: Write first review
SKU: 12694529
This OEM GM factory pump is a great upgrade to your LT Gen V build. The stock LT4 engine mounted high-pressure fuel pump will allow 35% more fuel flow with supporting modifications. SDPC specializes in late model LS and LT engine builds and we have seen serious HP numbers utilizing these factory direct-injection fuel components.
"Ask not what the camaro can do for you but what you can do with your camaro."
ChrisCoffey is offline   Reply With Quote
Old 03-29-2020, 01:17 AM   #6
s3rics213
My pump has the pn on it. It’s also the same pn from a 19 zl1 can’t even look up the pump for a 2020 which should still be the same pn of 12694529
SKU: 12694529
Looking to see if there’s a replacement harness or why someone did not wanting to cut up my harness for a connector if I can just get a new harness that works with what I have. Would be easier and quicker just don’t know if ones made.
Originally Posted by Heater View Post
I have 2016 and used 12679090 which was plug and play.
That number was replaced with the pn I already have
890/750 on 93/meth
Old 03-29-2020, 02:14 AM   #7
Tim M
Drives: 2018 Camaro SS 1LE
That is unfortunate...I would have expected interchangeability.
What does that sensor actually do?
Tim M is offline   Reply With Quote
Old 03-29-2020, 10:59 AM   #8
s3rics213
It’s not a sensor it the connector into the pump.
890/750 on 93/meth
Old 03-30-2020, 01:33 AM   #9
Tim M
s3rics213: I don't understand. Is this where the fuel rail pressure is passed to the ECU? Embarrassingly, I just upgraded to LT4 items and don't recall the placement of the sensors...
Old 03-30-2020, 07:11 AM   #10
Choda
Drives: Turbo 6.2
send it back and get another. I just did a lt4 hpfp last night on my 16 and it was a direct swap. Try DSX, talk to the rep and ask, send him pics of what you shown here. They are great to work with.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 03-30-2020, 08:14 AM   #11
ss2fast4u
2018 Camaro 1ss M6
Drives: 2018 Camaro 1SS M6/ LT4 SC
im going to be ordering an lt4 pump soon now Im getting worried which one to order lol
ss2fast4u is offline   Reply With Quote
Old 03-30-2020, 09:41 AM   #12
s3rics213
I have a 2019 so if you have a 16-18 this thread isn’t of concern. The pump in the lt1 on the 19 camaros have changed. The lt4 pump is the correct pump. For some reason in 19 that harness changed for how the pump gets its power.
its not a sensor that’s separate though it’s part of the pump see attached photo(circled connector) for the hpfp so if you didn’t connect yours you’d not have fuel.
It’s the right pump
you don’t have to worry you have a 18
890/750 on 93/meth
Old 03-30-2020, 11:12 AM   #13
Choda
Drives: Turbo 6.2
Originally Posted by s3rics213 View Post
It’s the right pump
If its the right pump then just plug it in and stop making the same thread in different sections. Obv we all think you somehow got a different pump because the connectors are different. Did you call the place you bought the pump from to see if there are different part numbers for a 2019 lt4 HPFP?
Old 03-30-2020, 11:28 AM   #14
gmcvt
gmcvt's Avatar
Drives: 2019 Camaro 1SS A10
I would think it has to be a sensor of some type?(pressue?) The pump is mechanical, not electrical.
"Jesus said to them: I am the way, the truth and the life and no one comes to the Father except through me" John 14:6
2020 Mustang GT M6
2019 Camaro 1SS A10 E85/Pray tuned & ported IM/TB.**SOLD**
2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD*
2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD*
gmcvt is offline   Reply With Quote
