03-13-2020, 07:06 PM | #1 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
Which to choose...more Air or Corn?
For those of you that have done one or the other, or even both at different times, which do you think is the best bang for the buck, and why?
Currently I can only purchase one of these, so just wanted to see what others did first. The car will be tuned once installed, and I hoping to eventually have both.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
03-13-2020, 07:26 PM | #2 | |
Cold air maybe 15+HP with your mods
DMS Flex Fuel-E85
HPTuners Ngauge Roto Fab CAI, LPE Ported/Polished 95mm LT5Throttle Body, PRAY Ported MSD Intake Manifold, SP Coated TSP 1 7/8" Catlless Longtubes Hooker BlackHeart Cat-Back, Mishimoto Catch Can (Which always has some nasty in it) Instagram@Weapon_6 |
03-13-2020, 07:53 PM | #3 |
I did the RF 1st and E85 last. I’d do the E85 all day over the RF. This is because it’s the best gain for the money plus you won’t have to deal with dirty tips. However, I have a question, is ported IM in your future plans?
03-13-2020, 08:41 PM | #4 | ||
I assume that's where the RF might be better huh? Thank you for your input!
03-13-2020, 09:02 PM | #5 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
If you have E85 available near you, hands down E85. Just get a better breathable performance filter and pop it in there. The Roto Fab does help a little and sounds better then the stock box.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
03-13-2020, 10:20 PM | #6 | |
Thank you for your advice/suggestions!
03-14-2020, 01:58 AM | #7 |
Drives: 2018 1SS M6 Join Date: Feb 2018
E85 for sure. Just know you need a tune with it.
03-14-2020, 06:02 AM | #8 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
By far E85 - but work with a reputable tuner that is known for E85 tunes. All the tuners can get it to run on E85, but there are few that know not just how to get the most out of it, but make the engine most "happy" on it.
CAI, if it adds any power, it is just peak power. E85 will give you torque everywhere
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
03-31-2020, 08:23 PM | #9 |
E85 all day
INSTAGRAM: @SUPAA_ANT
04-01-2020, 07:31 AM | #10 |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
Who is the best tuner for E85 ?
04-03-2020, 12:58 PM | #11 |
I went with Pray Performance on a remote tune. where you located in Michigan? im north of flint.
2018 1SS M6 - OTR intake, HI Ram intake, Ceramic Coated TSP Headers Catless, AWE Touring Axle-Back, Flex Fuel, Pray Performace stage 3 cam, TSP ported heads, Pray Ported 95MM TB and Ported HI-RAM. SJM Line-Lock. F14 Drag Pack 17's with front skinnies. Tuned by Pray Performance.
04-03-2020, 01:37 PM | #12 |
More air or corn? Both...duh!
Ok, ok... E85 first, then CAI.
04-03-2020, 02:09 PM | #13 |
why not both?
04-03-2020, 05:29 PM | #14 |
@texan.1le
Drives: '18 Camaro 1SS 1LE, PDR Join Date: Jun 2018
If you cant do both at once, then do corn first. There are much bigger gains to be had on the engine liquor.
'18 1SS 1LE - "Mongoose"
'15 Malibu 2LT - daily |
