03-05-2020, 06:28 AM | #15 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
I have MRC on my Camaro. I have Apex Wheels. 19x10 et20 and 19x11 et43. I was told its direct fit with 285/35 front and 305/30 rear with MRC. However I just purchased the Conti's ECS with 285/35 front & 325/30 for the rear. Again, I was told this should fit with no problem so I shall find out this weekend or next when the tires come in.. I will share my findings..
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- Last edited by Blackmonba6Gen; 03-05-2020 at 08:29 AM. |
03-05-2020, 10:02 AM | #16 |
Yes, I do.
As to tires you asked about, I'll go with Michelin PS4S for the front and Toyo R888R for the rear as an experiment, if the Toyos are too obnoxious without enough extra grip to compensate, I'll wear them down and switch to PS4S in the rear, too. Will report back with fitment info once these babies are on the car.
03-05-2020, 12:51 PM | #17 | |
Drives: 2016 Camaro 2SS Convertible A8 Join Date: Apr 2019
03-07-2020, 09:18 PM | #18 |
Okay guys, good news, 285/35/20 tires on 20x10 +23 front wheels and 315/30/20 tires on 20x11 +43 rears (MRR M017) fit without rubbing on my MRC car.
We did add spacers, 5mm in the front and 3mm in the rear, to improve clearance, simply because I didn't want to be so darn close to the edge, clearance would only be an uncomfortable 1-2 mm without them. The wiring harness on the driver side rear was relocated. Wheel studs appear to have sufficient thread engagement (8). I made a couple of closeup fitment pics for reference, see below. A bit more sidewall is going to be better for ride quality, and these sizes result in a closer-to-OEM non-1LE setup in diameter. The setup looks absolutely badass, there's a few mm of poke both front and rear, just as I wanted. Cornering grip is obviously much improved over stock. I only drove the car about 20 miles so far, no launches yet as it's still fairly cold outside and the tires are freshly mounted, but drivability is excellent, steering response feels great, no codes or stabilitrak warnings, a bit more tramlining. Now for the only slight negative so far, the new Toyo R888R's in the rear are noisy, which I of course knew going in, just want to state it for the record. Not as bad as the OE runflats, but there definitely is a distinct background whine, which will be okay with me for a while, it actually adds some cool factor, but once these wear out (and I can hopefully improve on my paltry personal best at the dragstrip), I'll probably replace these with PS4S.
03-07-2020, 09:58 PM | #19 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Great looking car Arpad
03-07-2020, 10:05 PM | #20 |
03-09-2020, 08:54 AM | #21 |
Looks great arpad_m! Since you had little issue with it, and me not having MRC, I'm thinking I'm going to go with the same sizes all PS4S, and I'm going to try to just relocate the harness without adding spacers. Hopefully it will be as you said and still have a few MM of clearance. Now that you've had them on a few days, how are you enjoying them? I bet those R888R's hook great!
03-09-2020, 09:13 AM | #22 | |
Everything feels very good so far with the setup, minus the tire noise, steering response is great, tons of grip from these Toyos, but the real test for them will be at the dragstrip of course.
03-09-2020, 01:44 PM | #23 |
BLUPRINT_1LE
Oh yeahhhhh that looks real good!
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
03-09-2020, 04:58 PM | #24 |
Blackmonba, appreciate it
Sending those beautiful bald eagles out the tailpipe never felt better
03-09-2020, 09:49 PM | #25 |
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8 Join Date: Dec 2018
Thanks for sharing the info arpad_m! I’m considering the 888r’s as well for the rears. The 315/30 look good in the fender wheels.
And sweeet looking ride! |
03-09-2020, 09:56 PM | #26 | |
2020 Shadow Gray 2SS
That shopping cart is giving me anxiety!!!
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
03-10-2020, 07:13 AM | #27 |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
I would personally go with the Bridgestone RE-71R. Grip level is similar, but they aren't quite as terrifying in the rain.
03-10-2020, 09:32 AM | #28 |
Drives: A10 ZL1 Join Date: Mar 2018
Could you explain more what needs to be done with relocating the brake harness?
Thread Tools | |
