12-14-2019, 01:07 PM | #1 |
Camaro Connoisseur
Drives: Red 2018 Chevrolet Camaro 1SS Join Date: Nov 2018
Throttle Body Connector Clip Broken...
This may be really dumb, but I’m having trouble disconnecting my throttle body cable from the TB itself because the little gray tab broke off. Didn’t realize how brittle the plastic became, and so I accidentally tore it asunder as you can see in the picture.
Is there any way I can disconnect it without completely destroying the connector? Thanks in advance!! Last edited by bowtie_thunder; 12-14-2019 at 02:19 PM. |
12-14-2019, 02:05 PM | #2 |
Drives: 2019 1SS Convertible Join Date: Jun 2019
IF I understand what has happened, grasp the sides of the connector and wiggle left/right while pulling it away from the throttle body. The clip (now defunct) is what locks it into place.
12-14-2019, 03:19 PM | #3 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
I had this happen to me, the gray tab crumbled under pressure!
I did as Blue said and slowly wiggled it out. I then took my car to the dealer for some rough idling and told them about it, I was trying to remove the TB to clean it hoping it would help with the idling. They ended up replacing #5 injector and the TB as well as a new connector, which works so much better. I have since removed this connector at least a dozen times with no issues. You may be able to have it replaced as well on your next visit, just let them know what you did and why...trying to clean the TB, yeah that's the ticket!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
12-15-2019, 12:52 AM | #4 |
Drives: 2018 1SS 1LE Join Date: Dec 2012
I find some of the connectors on the car to be very brittle. Same thing happen with some of my coil packs
12-15-2019, 10:20 AM | #5 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I could never understand why they make so many different kinds of locking mechanisms and setups for electrical connectors. They are all different and there is usually no way to tell how to get them off and there usually always in a hard to reach area.
12-15-2019, 01:13 PM | #6 |
I could not release my 02 sensors for the life of me...all four of them!
Unlock and push down...yeah right!
12-16-2019, 11:59 AM | #7 | |
Camaro Connoisseur
Anyway, yeah I'm going to try what Blue said. And I'll also go ahead and take it to the dealer to get a new connector. Thanks a bunch! |
12-16-2019, 12:01 PM | #8 |
Camaro Connoisseur
That and their overuse of tree clips is also just as annoying.
