Old 07-31-2020, 03:31 PM   #43
Hailwood
Drives: 2019 SS 1LE
On the street I don't use it very often and continue to heel/toe. Anytime I'm on track or autox though I use it since it's one less thing to think about and, especially on track, it's definitely worth some time.
Hailwood is offline   Reply With Quote
Old 08-05-2020, 08:23 AM   #44
foto1LE
foto1LE's Avatar
Drives: 2018 Camaro SS 1LE, 2002 Honda CR-V
I use it all the time.
2018 Camaro 1SS 1LE in Summit White
foto1LE is offline   Reply With Quote
Old 08-05-2020, 12:01 PM   #45
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Messing with it last weekend, pulling up to a stop light with pedestrians, they were not amused by the reving.
'18 1SS 1LE Black, PDR
Old 08-05-2020, 01:16 PM   #46
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
I have a habit of doing a quick left to right "wiggle" on the shifter to confirm it's in neutral. With NPP in Sport/Track and Rev Match on during street driving, that got annoying quickly (and embarrassing) with the rev match engaging. I now keep it off during most street driving through town. When the exhaust is in tour, it's much less obnoxious.
On a back road (or track I assume) the feature works flawlessly and is really nice.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 08-05-2020, 04:07 PM   #47
Boost Creep
Drives: '18 1SS 1LE
Yeah, always have the exhaust in track mode, so in town the rev match can be a little loud.
Old 08-05-2020, 04:58 PM   #48
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Simply sounds like a car is supposed to sound.
WRXs go "Psssssssssssssshh", our cars go "REEEVVVVVVV".
People are heel-toeing around town in these, you have turns in town that you need to heel-toe on? And then you'd do this rather than use the rev-match?
Seriously?
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 08-05-2020, 09:15 PM   #49
Boost Creep
Drives: '18 1SS 1LE
Seriously?
No, that was my point, the rev match is obnoxious in traffic.
Old 08-05-2020, 09:50 PM   #50
Aragorn
Drives: Camaro SS 1LE
Are use it every time, and get frustrated when I forget.
Aragorn is offline   Reply With Quote
Old 08-05-2020, 10:54 PM   #51
JamesNoBrakes
Drives: 2SS 1LE
So you jerk the car into gear?
2018 2SS 1LE
2023 Colorado ZR2
Old 08-06-2020, 08:12 AM   #52
Boost Creep
Drives: '18 1SS 1LE
If you noticed I mentioned the ECU blips the throttle more aggressively than I do. When I downshift you don't hear a blip because I seem to blip just enough for the rpm's to be 75-80% of what they should be versus the ECU blipping and holding rpm's to the exact rpm needed for the chosen gear.
Seriously?
Read.
Old 08-06-2020, 09:38 AM   #53
AD17SS1LE
AD17SS1LE's Avatar
Drives: 2017 Camaro SS 1LE
If you don't want the rev match to kick in you can shift to neutral and the rev match will mostly not engage, if it does its a small blip soon as you shift.
2017 Camaro SS 1LE
Pray ported TB/IM
TSP 1 7/8 Long tube headers w catted con pipes
Taylor plug wires
Mishimoto oil cooler
Elite X2 catch can
AD17SS1LE is offline   Reply With Quote
Old 08-06-2020, 09:54 AM   #54
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
Or just leave it off in the first place?
Nothing like an SS is offline   Reply With Quote
Old 08-06-2020, 11:00 AM   #55
NeverDie
The switch for rev match is quite literally at your fingertips as you drive. It isn't any more of an issue to toggle this setting than it is to activate a turn signal.
NeverDie is offline   Reply With Quote
Old 08-06-2020, 11:01 AM   #56
50MileSmile
50MileSmile's Avatar
Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28
I use it in town to lessen the load on the drivetrain, but on the track it’s heel-and-toe all the way. There’s nothing quite so orgasmic as the perfect 3-2 downshift!
50MileSmile is offline   Reply With Quote
