07-30-2020, 10:00 PM | #29 | |
Hot Camaro
07-31-2020, 06:27 AM | #30 | ||
Drives: '18 1SS 1LE Join Date: Sep 2017
Initial post you mentioned difference in MPH which I didn't get, but in the clarification you post MPG and that makes sense. Yes. Rev match does kill MPG in street driving if you downshift often, not a lot but maybe 1 or 2 mpg depending on traffic/conditions. I usually have the fuel range displayed in the dash and when Rev match is active that range will drop quicker than driving without. Didn't really think it would but the ECU blips the throttle much more aggressively than I do and will hold the rpm both on up and down shifts. On the highway you won't notice, but if you run up and down the gears in urban driving you will use more fuel. I down shift at every stop, so I noticed pretty quickly.
'18 1SS 1LE Black, PDR
07-31-2020, 07:11 AM | #31 | |
Hot Camaro
With DFCO, downshifting w/o a throttle blip should mean that MPG doesn't decrease because of a downshift. Any kind of throttle blip (manual or Rev Match) -should- cause a drop in MPG because you are actively feeding fuel to the motor. If you're manually revving the motor in pretty much the same way that Rev Match would, then it would seem there should not be any noticeable difference in MPG due solely to the use of Rev Match. |
07-31-2020, 07:32 AM | #32 |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
I would think an SS and an SS 1LE would have slightly different MPG no matter what. Different size/rolling weight of wheels/tires, different widths, decidedly different grip levels, these would all factor into the 1LE having lower MPG and may even make the "blip" MPG differ as well.
No facts here, just based on those differences alone they would differ to some extent I would think. |
07-31-2020, 07:34 AM | #33 | |
Hot Camaro
07-31-2020, 07:36 AM | #34 |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
I think people tend to downshift more aggressively at a higher rpm with rev match on vs doing it themselves in normal driving, I know I do. Maybe that could impact mpg's for some some with regards to rev matching yourself vs letting the ECU do it.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
07-31-2020, 07:38 AM | #35 |
Faster!!!
Both true statements
07-31-2020, 07:55 AM | #36 | |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
I drove my 1SS for just over two years and put right at 30,000 miles on it. I never reset my trip B odometer and when I traded the car in it showed average MPG of 20.9 I've been driving my 1SS 1LE for just over two years now and have recently passed 30,000 miles. I've left the trip B odometer untouched and it's showing right at 17.9 MPG. So 3 MPG less. Same house, same job, pretty much exact same driving routines. |
07-31-2020, 11:19 AM | #37 | |
07-31-2020, 11:20 AM | #38 | |
Hot Camaro
07-31-2020, 11:32 AM | #39 | |
I'm a little OCD about mpg.
07-31-2020, 11:57 AM | #40 | |
Hot Camaro
Here are the different situations that I was thinking of but didn't give a good description of. - No ARM, No manual rev match: Downshifts don't have much impact on MPG because of DFCO - No ARM, Manual rev match (me): Downshifts happen when the RPM's are around 1500-2000, one gear down doesn't need a significant "blip", negligible impact on MPG. Manual rev match is pretty close. - No ARM, Manual rev match (you - guessing a little here): Downshifts happen when RPM's are higher (3000-ish?), one gear down needs a significant blip but you don't run it all the way up, larger impact to MPG. - ARM (me): Downshifts happen when the RPM's are around 1500-2000, one gear down doesn't need a significant "blip", negligible impact on MPG. ARM is "perfect", and very close to what I would do manually. - ARM (you guessing a little here, too): Downshifts happen when RPM's are higher (3000-ish?), one gear down needs a significant blip and ARM runs it all the way up, larger impact to MPG. The higher blip from ARM is a big enough difference that you are feeling a larger impact. Probably still a bit off-base with at least some of it, but that was the basics of how I was thinking about it. |
07-31-2020, 01:46 PM | #41 |
Drives: '23 Hyundai Kona N, '24 VW GTI Join Date: Aug 2019
I use it all the time. I am a life-long heel-toe guy but it is so damn good. Especially when threshold braking on the track. I was worried about getting rusty, but the odds of a manual transmission car even existing the next time I get a new car are pretty low. And if I do get another manual, by then it will probably have the rev match feature.
07-31-2020, 02:48 PM | #42 |
I use it all the time, saves on the clutch. I can heel toe but not anywhere near as good as the rev match.
2017 Camaro SS 1LE
Pray ported TB/IM TSP 1 7/8 Long tube headers w catted con pipes Taylor plug wires Mishimoto oil cooler Elite X2 catch can |
