Vararam
Old 07-31-2009, 12:47 AM   #1
JewelZ
Just Lovin' My Camaro!
JewelZ's Avatar
Drives: CGM 2LT/RS/AUTO
What kind of gas are you filling up with in your '10 Camaro?
I'm thinking I won't be going to use regular unleaded in my 2LT/RS/AUTO(order status at 3300, yay!!) eventhough it is a v6 and only requires 87 octane, I will use 89 octane supreme. Or do you guys think there isn't much difference in the two and I might as well go Premium 91 octane, or just stick to regular 87 octane, and fill up 91 from time to time just to keep the engine clean? I know you guys who car about your Camaros are using Premium I hope.
Recommended Fuel
If the vehicle has the 3.6L V6 engine
(VIN Code V), use regular unleaded
gasoline with a posted octane rating
of 87 or higher. If the octane rating is
less than 87, you might notice an
audible knocking noise when you
drive, commonly referred to as spark
knock. If this occurs, use a gasoline
rated at 87 octane or higher as soon
as possible. If you are using gasoline
rated at 87 octane or higher and you
hear heavy knocking, the engine
needs service.
If the vehicle has the 6.2L V8 engine
(VIN Code W) or the 6.2L V8 engine
(VIN Code J), use premium unleaded
rating of 91 or higher. For best
performance, use premium unleaded
rating of 93. You can also use
regular unleaded gasoline rated at
87 octane or higher, but the vehicle’s
acceleration could be slightly
reduced, and you might notice a
slight audible knocking noise,
commonly referred to as a spark
knock. If the octane is less than 87,
you might notice a heavy knocking
noise when you drive. If this occurs,
use a gasoline rated at 87 octane
or higher as soon as possible.
Otherwise, you could damage the
engine. If you are using gasoline
needs service.
CGM( GRAY 2 tone interior ) 2LT/RS/AUTO
NJHKKM $29,965.00 1EH37 1100 03/28/2009 AFF, B34, DCP, FE9, GBV, LLT, MX0, SGC, UQA, WRS, 2LT
50 YEARS FROM NOW, DON'T YOU WANNA BE ABLE TO LOOK BACK AND SAY YOU HAD THE GUTS TO GET INTO THE CAR!?!?
ORDER STATUS : 6000 as of 08.18.2009. VIN# 33,985!!! His name is 'GOLIATH'!!!
GOT MY CAR!!!! AND I LOVE IT!!!!
JewelZ is offline   Reply With Quote
Old 07-31-2009, 12:51 AM   #2
Vash
Drives: 00 Blazer
Don't use super in the LLT V6. The plus should be fine it just mixes both tanks 50/50.
But you don't even need to use that it's designed and tested with just pump unleaded.
Vash is offline   Reply With Quote
Old 07-31-2009, 01:33 AM   #3
Rocky918
Rocky918's Avatar
Drives: SS for Super Sexy!
using a higher octane will put slightly less stress on your engine due to the slightly higher potential compression rate of the increased octane... but GM has engineered the LTs to run on regular and says so in the manual i believe... if i had an LT i would just use regular like the manual says and save a few bucks per fill up...
the SS however is designed for premium gas
- Life is to short to let it pass you by
Rocky918 is offline   Reply With Quote
Old 07-31-2009, 05:32 AM   #4
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '20 Corvette Stingray
I am and will be using regular, just likes designed for, anything more is a waste. I have another GM, and it sports the same engine, the 3.6 DI V6, it runs GREAT. putting plus or superme in will only drain you wallet faster, not give you better performaqnce.
Old 07-31-2009, 07:01 AM   #5
SoloSK71
SoloSK71's Avatar
Drives: 2010 Camaro 2SS
I will be filling up with 94 octane once I have the car
- SK
- 2G1FT1EW9A9132212
- Life is hard when destiny believes in you.
- As coherent as a pit bull in a spin dryer. A dribbling tartan frothbucket.
- Good money, bad girls. How can life be any better?
- God saves. The devil invests.
- This may be the ultimate guide to problem solving.
Originally Posted by MontyCarlo View Post
it's not a WD-40 problem, so it's got to be a duct tape problem
SoloSK71 is offline   Reply With Quote
Old 07-31-2009, 07:05 AM   #6
sigma_1966
My baby is here
sigma_1966's Avatar
Drives: SIM 2LT
94 octane. Purrs like a kitten.
sigma_1966 is offline   Reply With Quote
Old 07-31-2009, 07:17 AM   #7
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Drives: 2010 Camaro SS/RS #16429
What I don't get is the owners manual for my HHR SS states to only use 91 octane or higher on it's 2.0L Eco-Tec. So why do they not require it in the 3.6L, 44 more horse power V6 that's in the LT Camaro? Is it because the HHR SS is turbo?
I use 91 in the HHR SS & my SS/RS Camaro!
SSOOCH is offline   Reply With Quote
Old 07-31-2009, 07:24 AM   #8
Buckbo
Buckbo's Avatar
Drives: 2010 Camaro
Just follow the owners manual.
Buckbo is offline   Reply With Quote
Old 07-31-2009, 07:27 AM   #9
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
Running 93 down here in Alabama. 2SS of coarse though.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-31-2009, 07:30 AM   #10
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
I found the car tends always seems to pull a few more degrees and pulling timing more often when I'm using 87 vs 93... So while I can see the difference in the spark advance I think it's so small a difference you really can't feel it...
scrming is offline   Reply With Quote
Old 07-31-2009, 07:32 AM   #11
scrming
scrming's Avatar
Lot more to it than just HP... Don't know anything about the 2.0L... but you have to look at things like compression ratio, timing, A/F and now direct injection...
Old 07-31-2009, 07:55 AM   #12
Die Zielscheibe
Die Zielscheibe's Avatar
Drives: Lincoln Towncar, Chevy Camaro
My camaro hasn´t seen anything but Shell Optimax
Ordered:
2SS Imperial Blue
Delivered: 02.07.09
Die Zielscheibe is offline   Reply With Quote
Old 07-31-2009, 08:06 AM   #13
chrisgalles
TEXAS FIGHT!
chrisgalles's Avatar
Drives: Awesome
93 Octane
chrisgalles is offline   Reply With Quote
Old 07-31-2009, 08:23 AM   #14
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
Ive been using 87 octane Shell fuel and feel quite safe in doing so.
The V6 has a knock sensor on each cylinder.
Direct injection makes it possible to use 87 octane fuel in the engine in spite of it's 11:1 compression ratio.
two_wheel_mayhem is offline   Reply With Quote
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Exterior Parts & Accessories 30 02-20-2013 03:23 PM
Ultimate Camaro Playlist chevyridinghigh 5th Gen Camaro SS LS LT General Discussions 90 04-20-2010 11:00 PM
10 Camaros that should be built SSOOCH 5th Gen Camaro SS LS LT General Discussions 47 11-03-2009 05:46 PM
2010 Camaro, Decisions Decisions… (Winding Road Review) Xmicro_SS 5th Gen Camaro SS LS LT General Discussions 19 05-09-2009 11:40 AM
Detroit News panel wants GM to build Camaro concept Tran 5th Gen Camaro SS LS LT General Discussions 12 03-15-2009 04:38 PM
