TireRack
Old 07-29-2009, 05:13 PM   #1
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Cam basics
Thought id throw together some basic info on camshafts. I know there are people asking about cams and if they should swap one into their car... but they dont know what all the numbers/terms mean. so hopefully this helps. and more stuff will be added. as well as other tech things.
Lobe Lift
Refers to the distance, measured in thousandths of an inch, that the lobe of the cam is raised from the base circle of the cam. Increasing valve lift allows more air/fuel mixture to enter the cylinders and more exhaust to exit, which generally leads to an increase in engine performance. An increase in lift almost always leads to an increase in duration because increasing lobe lift requires more distance to create the opening and closing "ramps" on the lobe. However, today's computer designed, asymmetrical profile cams have a high acceleration opening ramp, while the closing side sets the valve down softly, helping longevity.
Valve Lift
Refers to the distance, measured in thousandths of an inch, that the valve is lifted off its seat at the cam lobe's highest point. Remember, the cam's rotary motion is converted to linear motion thru a lifter, pushrod, and finally a rocker arm. Therefore, valve lift equals lobe lift multiplied by the rocker arm ratio.
Lifters
A cam lifter, aka a follower, aka a tappet, makes direct contact with the cam lobes and follows the contour, or profile, of the cam.
Types of lifters:
Hydraulic flat-tappet
This type of lifter is self-adjusting, thanks to a valve controlled plunger inside its lifter body. engine oil pressure maintains preload against the pushrod, and since no lash allowance is needed, they run quieter than mechanical lifters. On the other hand, they can perform poorly at high rpm due to an inability to bleed down excessive oil pressure
Solid (Mechanical) flat-tappet
Essentially a solid link between the came lobe and the pushrod. Allows for greater rpm potential, since bleed-down is not a concern, but do require that lash, or clearance, be set between the valve and rocker arm to allow for expansion as the engine gets hotter.
Mechanical roller-tappet
Allows for the most aggressive lobe designs, due to the roller follower, and lends itself to high rpm operation, since its a solid body design. Like a solid flat tappet lifter, it requires a lash setting that must be readjusted over time.
Hydraulic roller-tappet
Used in OEM small blocks since 1987, allows for aggressive lobe designs along with self-adjustability an dquiet operation. They can, however, also suffer from bleed-down at high rpm.
One of the roller cam's greatest advantages is that rolling frictional forces are less than those caused by the "sliding" of a flat-tappet cam, which frees up some power. In general, roller-tappet profiles can be more aggressive for a given duration. On the other hand, a flat-tappet cam actually accelerates the lifter more quickly in the initial portion of the lift curve. With a sort-duration cam, a flat-tappet cam can actually get to a higher lift faster than a roller cam.
(pic from Gen-IV)
Duration
As lift refers to how far a valve opens, duration refers to how long it stays open. The opening time is expressed in degrees of crankshaft rotation, so a cam spec'd to 230* duration means the valve is being held open for 230* of crank shaft rotation.
usually referred to by two types of duration
Advertised Duration
The number of crankshaft degrees that the cam follower is lifted more than a predetermined amount off its seat. the SAE standard is 0.006 inch. So advertised duration is the number of crankshaft degrees that the valve is open at least 0.006 inch. ***Not all manufacturers use SAE standard***
Duration at 0.050 inch
Measures the movement of the cam follower, in crankshaft degrees, from the point where it is first lifted 0.050 inch off the base circle on the opening side of the lobe to the point where it decends to 0.050 inch off the base circle on its closing side. ***Common industry standard ***
Duration has a dramatic effect on engine performance. Stock camshafts usually offer relatively short duration and lift figures. This is done in the interest of a smooth idle and optimal part-throttle response. Longer intake duration opens the valve sooner in the cycle and closes it later. At lower engine speeds, this means the intake valve is still open as the piston begins to move upward, pushing the fresh air/fuel mixture out of the cylinder. On top of that, cylinder pressure can't build until the intake valve closes. The result is an engine with poor low and midrange respons. But the late-closing intake valve becomes an advantage at higher rpm, when the higher air inlet speeds keep filling the cylinders, even with the late closing valve. Basically, increasing duration will move the torque curve higher in the rpm range. Choosing a performance cam becomes a big compromise, you have to give some to get some.
Overlap
Overlap is the amount of time, measured in crankshaft degrees, that both the intake and the exhaust valves are open. This happens at the end of the exhaust stroke and the beginning of the intake stroke. Increasing duration or decreasing LSA, or doing both, increases overlap. A cam with an exhaust closing point of 4* ATDC and an intake opening point of 8* BTDC has 12* of total overlap
Lobe-Separation Angle (LSA)
Indicates the angle, in camshaft degrees, between the maximum lift points on the intake lobe and the exhaust lobe. Lobe separation is usually calculated by adding the intake centerline and the exhaust centerline, then dividing by two. For example, a cam with a 106* intake centerline and a 114* exhaust centerline has an LSA of 110* [(106+114)/2=110]
Narrower LSA
Increased overlap
Increased low-rpm torque
Narrower powerband
Reduced idle quality
Increased cranking compression
Decreased piston-to-valve clearance
Wider LSA
Reduced overlap
Improved top-end power
Wider powerband
Improved idle quality
Reduced cranking compression
Increased piston-to-valve clearance
Single and Dual pattern cams
Single Pattern
In this type of cam, the intake and exhaust lobe profiles are identical, using equal amounts of duration and lift.
Dual Pattern
This type of cam has different intake and exhaust profiles. In general, the exhaust lobe will employ more lift and duration to help evacuate exhaust gas from the cylinders.
more info
http://www.howstuffworks.com/camshaft.htm
http://www.secondchancegarage.com/public/156.cfm
photo thanks to UsedTaHaveA68
LS3 Cam specs
204/211 @.05 .551/.525 117
http://www.camarohomepage.com/ls3/page4.htm
L99 Lift specs
Camshaft Lobe Lift - Exhaust - Non Active Fuel Management Cylinders
7.48 mm
0.294 in
Camshaft Lobe Lift - Exhaust - Active Fuel Management Cylinders
7.61 mm
0.300 in
Camshaft Lobe Lift - Intake - Non Active Fuel Management Cylinders
7.48 mm
0.294 in
Camshaft Lobe Lift - Intake - Active Fuel Management Cylinders
7.61 mm
0.300 in
I piss excellence
and fart awesomeness
Last edited by CamaroSpike23; 07-30-2009 at 05:35 PM. Reason: Added: GM cam spec comparison sheet (corvettes) and L99 lifter pics
Old 07-29-2009, 05:52 PM   #2
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
thanks for the info man
ljustin293 is offline   Reply With Quote
Old 07-29-2009, 06:43 PM   #3
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
Sweet!
jpsuperman81 is offline   Reply With Quote
Old 07-29-2009, 07:23 PM   #4
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
There, are you happy now you have three.
By the way, Great info
Old 07-29-2009, 07:33 PM   #5
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Great info. Thanx.
Ok, that's my ass kising for the day.
Old 07-29-2009, 07:38 PM   #6
AntiVnm
AntiVnm's Avatar
Drives: '10 IBM Camaro
wow good crash course...ty spike
Dynateck 1 7/8 headers, CAI intake, Nitto DR, 3:73 Richmond gears, Vigilante 2800 stall converter, tune
AntiVnm is offline   Reply With Quote
Old 07-29-2009, 07:48 PM   #7
Hanzo
Hanzo's Avatar
Drives: '10 Black 1SS/RS LS3
You the man!
Hanzo is offline   Reply With Quote
Old 07-29-2009, 07:52 PM   #8
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
this is a great thread by a superbly intelligent human being. I wish I was as smart as Spike. I can only bask in the light of his automotive knowledge.
Eve ('00 FRC): hot-air intake
Old 07-29-2009, 07:54 PM   #9
68 Z/28
Father Time
68 Z/28's Avatar
Drives: 1967 Malibu / 2002 Caddy DTS
Send a message via Yahoo to 68 Z/28
Great info , should help clear things up for ppl not familiar with these things , good job
She's been sold ( Goodies List Updated )http://www.camaro5.com/forums/showthread.php?t=86262
68 Z/28 is offline   Reply With Quote
Old 07-29-2009, 08:02 PM   #10
CamaroSpike23
Truth Enforcer
thanks zebra. that really means a lot coming from you.
I piss excellence
Old 07-29-2009, 08:06 PM   #11
PQ
Booooosted.
PQ's Avatar
Ass kisser.
Old 07-29-2009, 08:15 PM   #12
Number 3
Hail to the King baby!
Number 3's Avatar
Great stuff Spike. About all you could want.
Can you add some info on VVT and cam phasing?
Old 07-29-2009, 08:25 PM   #13
CamaroSpike23
Truth Enforcer
planning on it. most of my info on vvt is stored at the house. I'm going to be creating a few threads over the next month or so about cams, blocks, heads, pistons/rods/cranks, transmissions, etc.
I piss excellence
Old 07-29-2009, 08:33 PM   #14
CamaroSpike23
Truth Enforcer
also, if any of you gearheads can think of something I missed, post it up and I'll add it in.
I piss excellence
cam
LS3 CAM AND HEADERS DYNO ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 53 02-13-2016 06:15 PM
Cam Vs. Cam Vs. Cam My First Camaro! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 12-11-2010 01:54 AM
ADM Stage 1 CAM - No tune required ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 61 06-09-2010 06:00 PM
LS3 Cam Package makes over 500rwhp!! Late Model Racecraft V8 Bolt-Ons & Tunes 45 07-19-2009 01:58 PM
