Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 4th Generation Camaros
Old 02-03-2011, 05:13 AM   #1
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Originally Posted by brandotron View Post
Approaching the 100K mile mark and my Z28 is starting to give me problems. Seems like it's always something
I like working on it, but I hate HAVING to work on it to keep it on the road. Last month it was o2 sensors, axle bearings, oil change. This month it's going to be transmission mount, spark plugs (pretty sure my bad o2's fouled a few plugs), and transmission fluid change. In a one car garage. Shoot me now.
transmission mount shoulda been one of your first mods/repairs/upgrades/whatever.
what all is it doing now?
Originally Posted by DGthe3 View Post
MY TAGS ARE ALL GONE!!!
WHOEVER HAS DONE THIS WILL PAY DEARLY!!!!!
I WILL HAVE MY VENGEANCE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Originally Posted by Xanthos View Post
Ever get around to this?
- X
yeah. I'm just trying to spec you out parts, and I got off early yesterday so I didnt do much of anything.
first off skip the roller tip rockers, either go full roller or leave the stockers, save the money for the pushrods and spend it on rockers. that cam seems overpriced IMO. IIRC, you can get a custom grind for ~$350 or so. stock pushrods are capable of .650 lift, so that money could be spent elsewhere
I piss excellence
and fart awesomeness
Old 02-03-2011, 08:20 AM   #2
CamaroSpike23
Truth Enforcer
Originally Posted by Da Hose View Post
Freakin hustlin this morning..... They are predicting sleet and ice starting around noon today and lasting until Friday evening..... The dumbass's here can't even drive when it rains.... this could be Armageddon for Houston....BWAHAHAHAHAHA
I piss excellence
Old 02-03-2011, 06:45 PM   #3
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Yeah, but doesn't the Crane 227 hold the cam only record for LT1s? That was the main reason I was looking at it. Sure, its a bit more expensive but it seems to be a proven part.
As for pushrods, I don't mind reusing the stocks I just figured since I was thinking of upping the rev-limiter to 6500 and the car has 114xxx on it, I might want to look into hardened pushrods. I think I might remove the crank from the parts list also though because upon further consideration, an aftermarket cast crank wouldn't be any better than the stock crank and I'd have to get it balanced anyway. Might as well just reuse the stocker.
- X
P.S. - I can get the cam here for 335, which seems to be as good a deal as any of the other cams.
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 02-04-2011, 06:57 AM   #4
CamaroSpike23
Truth Enforcer
Yeah, but doesn't the Crane 227 hold the cam only record for LT1s? That was the main reason I was looking at it. Sure, its a bit more expensive but it seems to be a proven part.[/
I thought I had taught you better than that. is your car going to be the new LT1 cam only record holder? the 227 is a good cam, in fact its one of the best OTC cams you can find. but remember that just because it works in a pure track car doesnt mean it will work as well for a weekend warrior dd
- X
As for the pushrods, IIRC, 93 and 94’s came stock with hardened pushrods to begin with. And as far as hardened, the only real benefit for hardened pushrods is if you are running guideplates. Because the pushrod hardening is to keep the outside of the rod from grinding away to nothing against guideplates with NSA rockers.
you can up the rev limiter to 7k if you want. the stock bottom end of these cars is twice as strong as most people give it credit for.
Here’s what I was running in my 94Z with 12.5 cr
230 / 240 - .544/.576 - 110 LSA
with a stalled A4, full bolt-ons, handported heads/intake, and some spray
IIRC, I paid around $350 for that cam (somewhat custom grind) 4 years ago
another option
http://www.lingenfelter.com/sites/li...mationv1.3.pdf
and another option is Comp Cams XE 230/236 if you can find it. I've seen some here an there used go for less than $200
also, you need to get some good springs/hardware to compliment the cam as well. I was running 918's for a while till they started having failures (not my personal ones, but Comp started farming out the manufacture of their springs and less quality came about). I switched to PAC 1518s that are good to .650 lift. the 1218s are good to about .600 lift and the 918's are about .625 lift.
I didn't see anything listed on the springs you had selected on what their max lift was.
also... you should do this in the 4th gen section. lol
and find some heads or have yours ported to maximize the cam.
I piss excellence
Old 02-04-2011, 11:33 AM   #5
Xanthos
PWA Relapse
Xanthos's Avatar
another option
I don't want anything too large cam-wise. I'll look into that LPE cam. As for the springs, I found them in this thread: http://www.ls1tech.com/forums/lt1-lt...ion-guide.html
Not sure on their max lift. I'll look that up also.
- X
Old 02-04-2011, 11:52 AM   #6
CamaroSpike23
Truth Enforcer
- X
I'm not wanting you to go with the biggest donkey di*k cam you can. even mine wasn't the biggest around. mine was set up for 40/60 split of track and dd. tho it was nicknamed the ThunderFu*k II cam...lmao
you have the benefit of the m6 that you dont have to fight as hard for idle characteristics or cam surge with a converter.
I piss excellence
Old 02-04-2011, 12:21 PM   #7
Xanthos
PWA Relapse
Xanthos's Avatar
Originally Posted by Shardik2SS View Post
Cam surge is a PITA!
Yay for clutch!
Also, that LPE cam looks like it would work as well. Also, those crane springs have an install height of 1.750 and a coil bind of 1.080, so they should be good for at least .600 or .650 of lift. Since I wouldn't be running anywhere close to that, they should be fine.
- X
Old 11-15-2011, 07:20 PM   #8
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Zabo's '00 T/A Build Thread
With the resurrection over, I decided to have the previous thread locked and relaunch the build thread in this thread.
Long short of my ownership:
- Found it wandering lots back in June 2010
- Placed a deposit, and swept it off the lot within 5 days of it's arrival there.
- Said dealership was a Ford stealership
- Needed Brakes and other minor work from sitting (29,718 miles)
- Drove trouble free (and learned to drive stick in the process) THROUGH THE WINTER of 2010/2011
- April 2, 2011 the car was totaled in a drag racing accident (sanctioned IHRA track).
- Secured a loan on the verge of bankrupting myself and rebuilt the car.
- Bill: $10,300; paid $10,395 for the car.
- Replaced door emblems with NOS 1998 Sport Gold Metallic emblems
- Rear bumper cover given the CETA (Collectors Edition Trans Am) blackout treatment
- Replaced the factory rear after discovering that the Torsen was KIA 10/2011
- Installed WS6 short stick, custom made 'Bandit shifter knob' from a 1977 Special Edition Trans Am, and TSB Rumbler Exhaust
- Purchased and installed AP tips, tucked TSP to gain a few inches in clearance
- Dropped the car off at Backstreet Performance in Medina and had the LTs and ORY installed, as well as the EGR pulled. Had them also reset the car for the lack of EGR/Cats/O2s
To do list:
- Weld up Cutout section and pick up/wire up an electric valve
- Purchase/install a Y pipe brace
- Install Prothanes
- Get a Daily Driver!
- GET A BETTER PAYING JOB!
- Pick up a set of Speedlines and widen rears to 11" for 315 rears
- Remount old tires on current PA6s for spare/storage use
- Put it away..
Down the road a few years:
- Strip the whole car
- Reweld the core support ('05 accident)
- Realign/Reweld (4/2/11 accident)
- Build/Swap the rear for road racing
- Build the transmission
- Respray in a custom factory Maple Red/Gold Flake mix
- Overhaul/breakdown and clean engine
And Pictures:
THE EARLY DAYS!
Finally got her home late in the evening..
Butt shot!
Interior when I got her home (not so pretty now.. and the stick shrunk)
Mileage when I got her home.
'00 Spec LS1
First good wide angle shot of the car
303hp at the rears w/ injector cleaner and clogged cats!
4/2/11
4/2/11. DO NOT CLICK IF YOU HAVE AN AVERSION TO AUTOMOTIVE GORE!!
Yeah.. it hit that hard. To this day the wheel still holds pressure. o_o
On the frame puller after welding/sealing
Welcome Home! (yes, that is a welcome home sign, parents made it)
WS6 SHORT STICK!
Stock spongey stick..
WS6 short stick! (6.5" model)
SLP BANNER!
Club banner decal
NEW FILLER PANEL!
Good bye faded filler panel..
Hello refurbished factory unit!
T/A NATIONALS!
Judging line, T/A nats 2011!
BANDIT KNOB!
Bandit knob prior to install
Completed Bandit knob!
EXHAUST!
Soon.. very soon
Out with the old
In with the BOOM!
Bow to my thunderous roar!
Youtube video testing my (at the time) new iPhone and making a proper recording of the exhaust
TIPS! -AP Stainless Dual Dual 3" Ovals
LONGTUBES & CATTED ORY!! Pacesetter 1 3/4" and Pacesetter 3" Catted (aftermarket high flows) Y pipe
Zabo is offline   Reply With Quote
Old 11-15-2011, 07:34 PM   #9
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 11-15-2011, 11:08 PM   #10
dmginc
dmginc's Avatar
Drives: In Circles
so ummm....when ya gonna do something new to it
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 11-16-2011, 06:10 AM   #11
Zabo
Gunning for Sixth
Zabo's Avatar
I dunno.. when I'm not swimming in bills?
Old 11-16-2011, 08:39 AM   #12
insidethreat07
It looks 100% better. Nice work
2001 Camaro V6
2016 Camaro 2SS
Old 11-16-2011, 09:36 AM   #13
dmginc
dmginc's Avatar
Drives: In Circles
you need an LS6 intake too Zabo!
Old 11-16-2011, 11:38 AM   #14
Zabo
Gunning for Sixth
Zabo's Avatar
The thread or the car?
You got one I could have for free? Otherwise it can wait.
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 611 07-01-2020 08:49 AM
Ph4r's Car - Boobies - Build Thread Ph4r Member Car Journals 42 03-20-2013 06:09 PM
Camaro5 Fest II Caravan/Convoy Thread tribone 2011 Camaro5 Fest (II) 13 04-12-2011 02:22 PM
Dumbest Camaro5 Question EVER! Beemer 5th Gen Camaro SS LS LT General Discussions 209 05-23-2010 06:11 PM
