Old 05-16-2020, 05:19 PM   #1
Walkure
Walkure's Avatar
Drives: '17 ZL1 A10 Vert
ZL1 emblem swap
I replaced the ZL1 emblems with the black ones from Wildhammer.
I had to replace the adhesive that came with the new emblems, but once I had that taken care of, everything else went smooth and the final result is exactly what I was looking for.
Walkure is offline   Reply With Quote
Old 05-16-2020, 08:12 PM   #2
Dragon08
Dragon08's Avatar
Drives: 2020 1LE
Nice!
Dragon08 is offline   Reply With Quote
Old 05-22-2020, 09:01 AM   #3
Cake's Z
Cake's Z's Avatar
Drives: 2018 ZL1
Looks great, I like how the red is matched! I just swapped my rear badge with a flat black with white "1". Cheap ebay/China badges but they look pretty good.
2018 A10 ZL1
2020 Can Am X3 XRS turbo RR
2019 TRD PRO Tundra (wifes)
2015 TRD Tundra (traded)
2014 Subaru WRX (traded)
2000 Z28 (sold)
1970 GMC 1500 (stolen)
2017 YXZ1000 (sold)
Cake's Z is offline   Reply With Quote
Old 05-22-2020, 10:43 AM   #4
20WHITEZL1
20WHITEZL1's Avatar
Drives: 2020 CAMARO ZL1
That looks great! What do you think of the overall quality of the emblems? I was looking at ordering a set from them to do the exact same thing.
2020 CAMARO ZL1
2012 SILVERADO LTZ
20WHITEZL1 is offline   Reply With Quote
Old 05-22-2020, 01:07 PM   #5
Walkure
Walkure's Avatar
They are solid, sturdy and look great. They are metal, while the factory emblems are plastic. At $18 a set they are a bargain.
But - as mentioned in other posts, the adhesive tape is white. Which is bad. On top of that, the adhesive on mine was horribly off-center.
Another user here removed the provided adhesive and recentered it on the emblems. I removed all of the adhesive that came with the emblems and replaced it with grey 3M tape. That took some work with an Xacto knife to cut out new adhesive. Then I used a black sharpie to color in the edges.
If you are ok with the adhesive, or fixing/replacing it, the emblems themselves are top notch.
Old 05-22-2020, 04:56 PM   #6
Walkure
Walkure's Avatar
Here’s a pic of what I mean about the adhesive that came with.
On the top is the adhesive that came with.
Middle is one with the adhesive removed.
On the bottom is one after I replaced the adhesive.
Old 05-31-2020, 06:47 AM   #7
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
I replaced my ZL1 and 1LE badges with the black ones, I found a set on Amazon but they had the white tape which didn't look right then I found these, https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
warren3537 is offline   Reply With Quote
Old 05-31-2020, 08:34 AM   #8
Walkure
Walkure's Avatar
Wildhammer price is actually cheaper than that Amazon link.
It looks like everyone uses white tape so you either have to live with it or replace it.
Old 06-06-2020, 03:41 PM   #9
20Bluezl1
I have the same issue with the wildhammer emblems. I even called them to ask before I ordered and they told me that they had changed the tape. I want to go install them today and guess what there white.
What 3m tape did you use and how wide i can only find 1/2"?
20Bluezl1 is online now   Reply With Quote
Old 06-06-2020, 05:01 PM   #10
Cake's Z
Cake's Z's Avatar
Drives: 2018 ZL1
Just installed a front grille emblem from emblempros.com. They use the gray tape. They are definitely more expensive than Amazon or wild hammer but quality is great.
2018 A10 ZL1
2000 Z28 (sold)
2017 YXZ1000 (sold)
Old 06-06-2020, 09:04 PM   #11
20Bluezl1
I guess I will be returning the wildhammer and ordering them from emblempros. What size did you get for the grille and does it have pins or is it use tape?
Old 06-06-2020, 09:30 PM   #12
Looks great and fits your color theme
Quick question, did you paint or powder coat the inside of exhaust tips, or is that all just soot ?
Old 06-06-2020, 09:39 PM   #13
Cake's Z
Cake's Z's Avatar
Drives: 2018 ZL1
I ordered the "small" for the grill. Exact fit as original. They do not use the pins, just the tape.
2018 A10 ZL1
2000 Z28 (sold)
2017 YXZ1000 (sold)
Old 06-06-2020, 09:52 PM   #14
20Bluezl1
So small for grille and medium for rear and hood
