Old 01-17-2022, 08:20 AM   #1
Fiyero88
Drives: 2018 Chevy Camaro 1LT
Lock Pillar Trim Removal and Replacement
Does anyone know how to get the seatbelt off the lock pillar trim? I purchased a new lock pillar piece but the seat belt threads through it and I don't know how to safely remove it to put the new piece on. It's the plastic piece by the headliner that has a hole where the seatbelt goes through. I'm stuck right now so any help would be great.
Fiyero88 is offline   Reply With Quote
Old 01-17-2022, 08:39 AM   #2
Fiyero88
If I remove this torx, will I set a airbag off or something? I'm trying to do this without removing the battery terminal since I'm just replacing a plastic pillar trim piece.
Old 01-17-2022, 11:09 AM   #3
Efi69Cam
Drives: 2016 Camaro SS 2017 Yukon Denali
I did the same repair on mine, people with rings scratched it all up. Yes, remove that bolt and you will be able to pull the end through. Watch the twist on the belt when you put back together
Efi69Cam is offline   Reply With Quote
Old 01-17-2022, 11:57 AM   #4
Fiyero88
Thanks soo much! It was a simple replacement and it worked. Yeah someone gauged the hell out of mine so bought a new one.
lock, pillar, removal, seatbelt
