Old 02-28-2018, 10:20 AM   #1
Epx998
|Engineer|
Epx998's Avatar
Drives: 2016 Camaro SS
Magnuson guys in Calif (Pulley size/boost) ?
What size pulley are you using and what getting in your cars??
Epx998 is offline   Reply With Quote
Old 02-28-2018, 11:56 AM   #2
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
by default, I think they ship with 98MM pulleys. I just upgraded to the 95MM which is good for about a pound of boost or so, from what others are saying.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 02-28-2018, 01:21 PM   #3
Epx998
|Engineer|
Epx998's Avatar
The kit I ordered from Jannetty is with the 85mm pullet, he suggested I not run 91 and full throttle, that had me a tad concerned. I am still learing the in/outs if FI. He also suggested just having two and swapping out as needed. One for 91 octone, lower boost and all then another for when I want to start adding E85 into the mix. Seems like a good idea.
Wondering though when the bottom end needs to be upgrade beyond fuel components.
Old 02-28-2018, 07:37 PM   #4
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I wouldn't run below a 90 on the street, 85 is pushing it on 91 or you need to run Water/Meth as extra fuel . I've been thru all these pulleys, 90 is a good one for the street with good fuel, be careful on timing. Listen to Ted and you should have more then one pulley if your going to drag race, but you need to be able to tune it yourself or buy hp tunes and have the shop that tunes it add more then one tune.
Old 02-28-2018, 08:51 PM   #5
Epx998
|Engineer|
Epx998's Avatar
Roger that.
Old 02-28-2018, 10:16 PM   #6
boostednut
Drives: Nothing cool atm
... or buy hp tunes and have the shop that tunes it add more then one tune.
Is there a way to switch tunes on the fly through like cruise control on hp tuners in the 6g?
boostednut is offline   Reply With Quote
Old 02-28-2018, 11:30 PM   #7
Drsagacity
Drsagacity's Avatar
Does this sound about right?
98mm - 6psi
95mm - 8psi
90mm - 10psi
85mm - 13psi
Don’t want to hijack, but are people using a boost gauge?
Old 03-01-2018, 09:42 AM   #8
oneredry
HYPER SS
oneredry's Avatar
98mm - 5psi
95mm - 7psi
90mm - 10psi
85mm - 13psi
I'd say 98MM will hit 7. I've touched 7 multiple times on my factory issued Maggie. Then again I have an intercooler, I think it changes if you have an intercooler or not, according to Magnusons website.
Ordered: 1/15/2016
Delivered 03/23/16
Old 03-01-2018, 10:40 AM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
No...you have to flash the tune with the engine off each time. Not sure why it would matter because you cant change pulleys on the fly anyways.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 03-01-2018, 11:41 AM   #10
oneredry
HYPER SS
oneredry's Avatar
not sure if he was thinking about turbo's. Turbo vehicles you can adjust using boost controller on the fly.
Ordered: 1/15/2016
Delivered 03/23/16
