02-28-2018, 09:44 AM | #1 |
Drives: Camaro Join Date: Nov 2017
What fueling mods is needed for E85?
Hey guys,
I have been reading all the threads on fueling and it seems like there is a lot of different answers about how much power you can achieved on certain fuel setups. I’m look for 625-650whp on 91 or 675-700whp on E85, I would like not to install a cam just in case I have to go back to stock at some point, Thanks for the info guys. |
02-28-2018, 10:29 AM | #2 |
Drives: 2016 Camaro 2SS Join Date: Sep 2016
I've spoken to just about everyone and the general consensus is that you will peak out at 630-650 on e60ish. If you want anything over those numbers you would absolutely have to upgrade your cam or go to a secondary port injection system. Both cost over 5k installed from what I have seen.
02-28-2018, 11:13 AM | #3 | |
660 RWHP is where I feel the limit is on the LT-4 fuel system parts on our particular Superflow Dyno and our 17 1LE car, Heartbeat, 80mm pulley, Rotofab, LT headers, w cats, with exhaust back to stock NPP muffler. Numbers may vary from dyno to dyno and car to car. Ted.
www.jannettyracing.com
02-28-2018, 10:24 PM | #4 |
What octane is E60?
How far can you go on the stock fuel system? |
02-28-2018, 11:22 PM | #5 |
I don't believe you can safely run a forced induction setup on E85 with the stock fuel system and cam. On 93 you can get to 580-600whp depending on dyno.
2016 NFG 1SS A8
03-01-2018, 07:20 AM | #6 | |
The stock fuel system can not be used with forced induction and E-85. The stock fuel system can make 580 RWHP on Gasoline. Ted.
