Old 11-22-2016, 02:20 PM   #29
F1FTY
Drives: 2018 ZL1
Originally Posted by Gefiltefish View Post
I just did my winter swap this past weekend. Used the ZL1 pinch weld with "puck" and lifted each side on the pinch weld right under the door seam. It lifted the front and rear high enough that I could swap both front and rear wheels.
excellent, thank you! I just ordered the ZL1 kit from Amazon to get this done.
F1FTY is offline   Reply With Quote
Old 11-22-2016, 02:35 PM   #30
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Am I a complete moron for even asking why the jack stands don't damage the pinch welds?
I performed lots of work on motorcycles, ATVs, snowmobiles, and watercraft, as a paid and factory trained professional for years, but on cars, I have very little clue.
Emoto is offline   Reply With Quote
Old 11-23-2016, 04:21 PM   #31
vaspen
vaspen's Avatar
Drives: 2017 l4 blue 6speed
here is where I placed the car on a 4 post lift and didn't hurt anything next time however I will use the pinch weld in the back and the front the 2 flat spots
https://postimg.org/gallery/1g648ne6o/
picture sharing
vaspen is offline   Reply With Quote
Old 02-19-2017, 04:07 PM   #32
Rich Alsip
Drives: 2016 2SS convertible black
Originally Posted by Bad Rap View Post
Sorry to say, you can only use the front pinch weld jacking point on the verts!
The one back little for your jack stand has the cross brace bolted to it. Also you can't get to the center jacking point in the rear because of the rear cross braces! At least we get to go topless!
Seriously, I can't jack each rear corner to switch out wheels?
Rich Alsip is offline   Reply With Quote
Old 02-19-2017, 04:11 PM   #33
Rich Alsip
Originally Posted by JBinSD View Post
Since there is only one pinch weld available on the verts, how are people lifting and supporting the verts?
Did you get an answer to this question, ? I as well need to know best way to lift each corner to switch out winter set ups for my summer ones
Old 02-19-2017, 04:16 PM   #34
Rich Alsip
Ordered the universal mag pad, and I'm wondering if I got the wrong one. The magpad wobbles , doesn't fit snug on the pinch weld , that can't be right, can it?
Old 02-19-2017, 06:20 PM   #35
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Mine wobbles a little too but once the jack pad on the pump jack itself touches the magpad it centers on the pinch weld and no longer wobbles. When I let the car down to settle on the jack stand all was good. No worries - just let the jack pump release as slowly as you can and it will settle properly on the jack stand.
476 rwhp/440 rwtq (sold)
Old 02-23-2017, 06:29 AM   #36
Rich Alsip
I looked under mine 16 2SS vert, and it looks like the rear pinch is accessible, you say no good?
Old 02-27-2017, 11:52 AM   #37
JBinSD
Drives: '23 LT Vert M6'16 Hyper 2SS Vert MT
Yes, I ended up lifting with the open pinch weld, and using stands with the braces, they appear strong enough to hold the weight of the car with no bending or shifting. I use smaller (2 ton) jackstands (prox $8 at Wallymart) and the width fits nicely with the brace in the second pinch weld area.
JBinSD is offline   Reply With Quote
Old 04-06-2017, 02:34 PM   #38
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
Well apparently they don't sell hockey pucks in my local sporting good store. So I pulled the trigger on the mag jack/puck combo, but was kinda bummed about the $11 shipping charge. $65 for this is about $15-20 too much for what your getting IMO.
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
Adrian97c is offline   Reply With Quote
Old 06-18-2017, 10:00 AM   #39
SSFIFTY
SSFIFTY's Avatar
Drives: 2017 Camaro SS FIFTY Coupe
80/20 for the pinch weld jack point
I had a scrap piece of 80/20 laying in the garage. I cut it to 2 3/4 inches and it works great on those pinch welds. Just need to find a rare earth magnet to glue inside of it and it'll be perfect.
SSFIFTY is offline   Reply With Quote
Old 12-06-2021, 12:50 PM   #40
flyinmach1
Drives: 2019 Camaro SS Riverside Blue
Originally Posted by SpookShow'84 View Post
Tagged
Super old post I know, but that Monte Carlo sounds bad ass SpookShow'84! Love the sound of an older muscle car with a lopey idle cam! Nice job!
flyinmach1 is offline   Reply With Quote
Old 12-18-2021, 02:59 PM   #41
chisox05
Drives: 2022 Camaro ZL1
I am going to be ordering a 22 Zl1 and will be putting the jack pads on the pinch weldS but I am wondering what the clearance is ground to jack pad. I want to see if I will need to get a new lower floor jack.
chisox05 is offline   Reply With Quote
Old 12-18-2021, 06:14 PM   #42
I have an SS with 305/35/20 rear and 285/35/20 front tires on 1LE wheels, which isn't exactly the same as what you'll get with the ZL1.
However, at least as a data point, my ground clearance with the ZL1 Addons lift pads in place is 7" in the rear and 5.5" up front. I have a Daytona 3-ton low profile jack that fits under the car with no problems.
