11-15-2013, 05:32 PM | #29 | |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
A: They do, but only if the case makes its way into a courtroom. Most cases never do. A lot of people will fold and take the denial with only a little fight. The customers that push and escalate usually get satisfaction before it goes to court. However, the sweet little disclaimer of warranty in the event of modification or abuse that all manufactures use, gives them a lot of latitude to deny warranty. Straight from my owner's manual: "As the vehicle owner, you should also be aware that GM may deny warranty coverage if your vehicle or a part has failed due to abuse, neglect, improper or insufficient maintenance, or modifications not approved by GM." Q: Define abuse please? A: Notice that GM does NOT define abuse in the above statement. Again, abuse can be anything they deem it to be. From a dealership standpoint, abuse is defined by a component that failed for any reason outside of wear, or manufacturer defect. When abuse is suspected, the dealer will look for other clues. How much tread is on the tires? Are the rear tires worn more than the fronts? Excessive tire wear as compared to mileage? Excessive brake dust? Etc. Q: Is it subjective and case by case? A: All warranty is subjective, and treated case-by-case. Q: You are making it sound like if you change anything the dealer will blame you and not the part itself. A: I am stating the they could try and blame your mods, or you. Some dealers love to blame mods for failures before they even get a full diagnosis done. Again, this is not about GM specifically. This is about new car warranty, period. You would be amazed at the lengths dealers and corporate regional managers will go to in order to deny a warranty where abuse or modifications are suspected. Dealers get dinged for excessive warranty claims. They lose dealer incentive dollars because of them. Also, when performing a warranty repair, the dealer collects 25%-45% less than if the job were customer-pay. Since a service manager's pay is based wholly on shop dollars, there is a direct motivation to deny your warranty. Good dealers won't do this, since they value the long-term relationship and your future business. It's a dicey game.
Bye bye, Bumblebee!
11-16-2013, 04:18 PM | #30 |
Drives: 13 ZL1 vert blac fastlane/LPE 750 Join Date: Jul 2011
The fact is if your worried ,and cant afford to fix it if it blows up,don't mod it period...
No matter what the case is there is some truth in most of all the statements,but you wont find out until you open up that can of worms...
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
11-16-2013, 04:59 PM | #31 |
Drives: 2018 ZL1/1LE Red Join Date: Oct 2013
Considering the ZL1 is advertised as a track worthy vehicle, specifically with 5 driving modes of which three sport, and the final two track oriented... if you are doing a "drivers education" session which is NOT racing with clubs such as PCA, BMW, MVP, CHIN...etc, and your ZL1 has no modifications other than a semi-slick (eg. sport cup, 60ish tread wear) then if lets say a suspension part fails. You are covered. Your engine blow and you have not done a missed shift with an extreme over-rev, you are covered. GM has nothing to stand on because they have this car designed as such.
BobR
2018 ZL1 1LE (Red) - New Dec 2017 2015 ViperGT (Gunmetal w/Red stripes) 2013 ZR1 Anniversary 2014 ZL1 - BrightYellow, 6sp 2011 Porsche GT3RS - White w/red graphics 2009 Porsche C2S 2001 Ferrari 360 |
11-17-2013, 12:18 AM | #32 |
Drives: 13 zl1 crt convertible Join Date: Aug 2013
a good example of warranty denial even though it is an obvious parts failure, brake pads corroding - separating from their backing. ive seen this happen at very low mileage & within 1 year old. they are considered a wear item
11-17-2013, 08:10 AM | #33 | |
Agreed. Any form of wear item like brake pads, clutch...etc would not be covered unless in xx miles you had excessive wear from just normal day-2-day driving. Pads...rotors with normal use could hit an easy 30K miles if not much longer. I'd suspect though on the ZL1 with the Brembos and on floating rotors they have a more track oriented pad compound on them...not pure race by any means but obviously meant to stop the car when on the track.
BobR
04-04-2014, 05:25 PM | #34 |
RedLine
I know this is an old thread but thought I should update it by Letting everyone know that Gm just warrantied my front rotors for heat spots and cracks and noise no questions ask at 20,600 miles. I told them that I track the car at Mid Ohio and they said no problem we will have the rotors here in a couple of days! just a little Proof that GM is standing behind their warranty claims with this car.
2018 GMC 2500 "Blue" (Sold)
2018 ZL1 1LE Hyper Blue" (Sold) 2018 CTS-V "Black" (Sold) 2022 GMC 2500 "Blue" 2022 ZL1 1LE 6spd "Rapid Blue" 2023 ZL1 1LE Auto Rapid Blue (ordered) |
04-04-2014, 06:04 PM | #35 | |
Go NY Giants & NY Rangers
Drives: 2013 ZL1 M6 Join Date: Nov 2013
Some guy had a BMW M3 and put in aftermarket lights. Somehow it caused a short or something, and started a fire. Neither BMW or his insurance would pay.
Molon Labe!
04-04-2014, 06:17 PM | #36 | |
Drives: 2013 ZL1 Join Date: Oct 2011
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
04-06-2014, 03:55 AM | #37 |
wow...I purchased a new set of rotors recently due to track torture...thought there was no way GM would cover a "wear item". Amazing.
