dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 06-18-2013, 10:38 AM   #1
Mister Will
Mister Will's Avatar
Drives: 2021 Camaro ZL1 A10
Question about the ZL1 drivetrain?
First I realize that this is probably an obvious question, and I also could probably figure it out. However, I'm sure a lot fo you could answer this question off the top of your head. Please explain.
Does the ZL1 have the same drivetrain, clutch, trans, rear end, as a 1LE.
This is an offshhot from another thread in which the issue of "just" putting a supercharger on an 1LE and you wil have ZL1 power from a SS.
Mister Will is offline   Reply With Quote
Old 06-18-2013, 11:52 AM   #2
cam99
cam99's Avatar
Drives: 2012 ZL1
I believe the tr6060 is different in the zl1 (mines an auto so I'm not well schooled on the m6 in them), however the rear end and axles are completely different in the zl1. It has a 9.9 inch rear made of cast iron, not aluminium, and larger axles. It's not an issue of producing the horsepower from an ss to zl1, but all the other areas that need attention on the ss to handle the extra power. So the blower is just one part of the equation, the entire drivetrain was engineered to take the extra power in the zl1, on an ss or 1le you have to make changes to get the drivetrain "bulletproof"
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
Old 06-18-2013, 11:57 AM   #3
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
The tremec6060 in the ZL1 is an MG9 which can handle 30% more torque. The rear gear in the ZL1 is 3.73, 3.91 in 1LE. The LSA has hypereutectic pistons, piston oil squirters and forged rods. The clutch in the ZL1 is beefier as well.
Old 06-18-2013, 04:43 PM   #4
Mister Will
Thanks for the details guys!
Like I said earlier, it only makes sense that GM would beef up the drivetrain with the increased power. Thanks for the details.
