Old 05-25-2020, 12:09 PM   #1
Ren Lacerda
Ren Lacerda's Avatar
Drives: 2017 2SS M6 FIFTY
Brake calipers bolts help needed
Hello everyone! I'm a novice on self-maintenance, having a blast learning to keep my 2017 2SS ready for track days and HPDE.
I'm stuck on installing GM's track brakes cooling kit, more specifically with removing the 4 piston Brembo front calipers' bolts:
1. What are the right size bolts? 19mm and 3/4 are little lose, 17 and 11/16 won't fit. Are these 18mm or 23/32?
2. The bottom caliper bolt is in a tricky angle, even with the sterering wheel all turned in to the right. Are swivel sockets an appropriate solution here? Can I use my impact wrench + swivel sockets to lose these two piston bolts?
3. Can I reuse these piston bolts every time I install/remove the track brake cooling kit before/after track time, as long I'm using the correct spec threadlocker?
Thanks in advance!
Ren Lacerda is offline   Reply With Quote
Old 05-25-2020, 12:40 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Thanks in advance!
18mm
If you turn the wheel all the way you can get an 18mm deep socket and a standard impact wrench on both bolts.
Yes, you can reuse the bolts, proper torque 148 ft/lb.
Thread locker is Loctite 272
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
Old 05-25-2020, 01:04 PM   #3
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
I know it's been debated on here before but those are torque to yield bolts... Which means that they stretch when they're properly installed and I replaced mine when I did my rotors for peace of mind. Plenty of people have reused those bolts though and I've never heard of any failures... So really I guess it's a personal choice.
Sent from my Pixel 4 XL using Tapatalk
terry_b is offline   Reply With Quote
Old 05-25-2020, 01:52 PM   #4
2SS Capt
2SS Capt's Avatar
The GM document for the Track Deflector and Splash Shield installation (GM Part #23385148) doesn't say anything about not reusing the caliper bolts. (There is no mention on replacing the bolts, just reinstalling with Loctite).
Old 05-25-2020, 04:14 PM   #5
Ren Lacerda
18mm
Thanks 2SS Capt, 18mm ball swivel socket + 18in breakbar did the trick!
About the torque, service manual says 111 lb ft first pass and 15-30 degrees 2nd pass. What does that 1st and second pass means?
https://imgur.com/a/Or4ZHHC
EDIT: Nevermind, found out what torque+angle means. Gotta use a tool like this for the second final pass:
https://www.autozone.com/test-scan-a...uge/141510_0_0
Old 05-25-2020, 04:28 PM   #6
2SS Capt
2SS Capt's Avatar
Interesting as the Track Deflector and Splash Guard instructions say 148 lb/ft...
I would say first pass, tighten both to 111 lb/ft and then go back to each and tighten an additional 15°-30° of turn (I'm guessing that will put you somewhere near 148 lb/ft of torque )...
Old 05-25-2020, 04:45 PM   #7
Ren Lacerda
I "calculated" the same, 111+15-30 degrees=148 lb ft
Old 05-25-2020, 08:12 PM   #8
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
all of the fasteners are metric even though there are standard equivalents of some sizes
Old 05-25-2020, 08:42 PM   #9
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
18mm
this is correct.
there are no torque to yield bolts except maybe the head bolts. iv measured then all with a micrometer. none stretched and GM even states now you can reuse the caliper bolts.
Old 05-26-2020, 04:59 PM   #10
Ren Lacerda
Originally Posted by JCunningham View Post
this is correct.
Awesome confirmation! Thanks JCunningham.
Old 05-27-2020, 09:23 AM   #11
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Thanks in advance!
Just leave the kit on, plenty of us do with no issues and it's really not worth the hassle of removing every time. If you are against that I would still say only remove the actual air deflector on the control arms and not worry about removing the calipers to put the rotor shield back on.
Old 05-28-2020, 06:34 PM   #12
Efi69Cam
Drives: 2016 Camaro SS 2017 Yukon Denali
A torque angle spec does not mean it’s a torque to yield bolt. The yield point could affect the reading on a torque wrench so all tty bolts are installed with torque angle specs.
Torque angle is more reliable as it takes the friction out of the equation when tightening the bolt to the stretch the engineers intended. On these brake bolts simply using a liquid thread locking compound instead of the dry the new bolts come with would change the torque reading. Torquing to 148 lbs would result in more stretch on the bolt with the liquid.
Efi69Cam is offline   Reply With Quote
