05-23-2020, 10:41 PM | #1 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Torque specs for FE4 swaybar and end links
Hey guys, I am in the process of installing the 1LE sway bars and end links on my '16SS. Can someone save me renting the helms manual for a day and let me know the torque specs? I have everything loose installed and ready to torque but don't have the torque specs as i purchased the bars, end links, and hardware separately so I didn't get the instructions from GM.
Baby Blue
05-25-2020, 06:59 PM | #2 |
Drives: 17' 2SS Join Date: Sep 2016
16 ft lb on the sway bars....
30 ft lb on the end links I believe so.... well hope so... |
05-26-2020, 07:30 AM | #3 |
Torque Specs
Thanks, Bx-SS. Do you happen to have the specs for the handling links? They use torque-to-yield bolts common to the front cradle, and a tapered pin common to the steering knuckle.
On a related note, I notice that the GM handling kit does not include the sway bar end links, however, the FE3 and FE4 suspension use different part numbers. Does anyone know what the difference is? I'll have to measure the parts on my Buddy's 1LE when I get the chance.
Baby Blue
05-26-2020, 10:13 AM | #4 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
The sway bar bracket torque is correct, but that's not the sway bar link torque.
Lower sway bar link is 96 ft-lb. Upper sway bar link is 89 ft-lb. Also supposed to use new nuts on those since they're prevailing torque lock nuts. Not sure what you mean by different links. I see the same 23240970 and 23240971 for both FE3 and FE4. Could have just been a coating or material change or something like that if part numbers changed over time, but performance-wise you should be fine with what you have. To answer your second question: They TTY fastener for the ride link is 74 ft-lb plus 90-105 degrees. The nut on the tapered shank is 30 ft-lb plus 120-135 degrees.
2017 SS 1LE.
05-26-2020, 12:57 PM | #5 |
Thanks, Alpha. I got all new hardware, although it's debatable weather or not it's actually necessary. As for the links, it pretty confusing. I see the 970 & 971 links, however, the 970 is supposedly good for the LH side on FE4/FEA cars, the 971 is listed as good for the RH side on FE3 cars. I'm just going to roll with my originals, but you have admit it's a bit confusing.
Baby Blue
05-26-2020, 02:20 PM | #6 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
FE3, FE4 and FEA sway bar links should be the same.
05-27-2020, 10:58 AM | #7 |
Yep, that's what I figured. You certainly have to read between the lines to interpret from the parts list though.
Now that I'm armed with all the specs, I'll start buttoning everything back up, assuming I feel energetic enough when I get home this evening. Thanks everyone for the help!
Baby Blue
06-12-2020, 10:05 AM | #8 | ||
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Matt Miller
2020 SS 1LE |
06-12-2020, 10:42 AM | #9 |
be very carefull to not overtighten the swaybar mounts otherwise they will break ask me how i know lol
