05-14-2020, 05:15 PM | #15 | |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
“I think” the quality of the gas you run (i.e. Chevron over “cheaper” gas) MAY have an impact but I’m not convinced of that either. The more gas you give her the more soot it’s going to produce. |
05-14-2020, 06:21 PM | #16 | |
Drives: 19 Z06 Join Date: Nov 2011
Gone but not forgotten:
1974 Corvette Stingray 454 1986 Z28 2009 Mustang GT convertible 2012 45th 2SS Vert 2013 ZL1 M6 2014 Zl1 M6 2014 GT500 2016 Challenger Hellcat M6 www.youtube.com/c/garageking |
05-14-2020, 06:30 PM | #17 | |
The dual port system is the way to go for sure.
05-14-2020, 06:46 PM | #18 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
That is great elite. I cant put your CC on the back right, because I have my SC reservoir mounted there. When are those front brackets going to be available?
05-14-2020, 07:43 PM | #19 | |
Drives: Chevy Camaro ZL1 Join Date: Apr 2020
Absolutely agree, the black tailpipe soot is unavoidable. With a good CC however, the time until cleaning may be extended. Time will tell... Chris |
05-15-2020, 12:35 AM | #20 |
Drives: 2019 ZL1 Join Date: Mar 2019
Name and number of the shop that did your work? Thanks
05-15-2020, 01:30 AM | #21 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Why would it work better in the front than on the side?
Does the temp have so much effect on suction? Or vapor to liquid effect are poor inside the can when it’s hot? Mine is on the side and it works fine... 1 inch in a cup after 3000 miles, 1 inch in a cup after 60 min of track |
05-15-2020, 08:42 AM | #22 | |
Drives: 2020 ZL1 1LE M6; previous 2018 ZL1 Join Date: Jun 2017
What's the part number for the modified L bracket?
"Don't let the sound of your own wheels drive you crazy!"
05-15-2020, 11:08 AM | #23 | |
The only contact phone number I have is a personal cell phone and I won’t publish that here until I’ve heard back from the person I left a message with. Contact Elite Engineering if you need a faster response. Quote:
05-15-2020, 11:31 AM | #24 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
There is gas and water in the blowby - cooler is better to reduce vapor pressure of the nasties. Larger can with more residence time/bigger velocity drop helps too of course.
So why did they mount it there in the first place is the real question, the MM can has always been in front |
05-15-2020, 12:58 PM | #25 |
05-15-2020, 01:44 PM | #26 |
Drives: '22 Summit White ZL1 A10 Join Date: Aug 2019
I chose a fender mount style on the Hellcat and it was more than twice the amount of hose, they said that style allowed for cooling of the vapor and was actually the better choice between the 2 mount styles.....don't know if that's true, but I bit on the sales pitch.....
05-15-2020, 02:06 PM | #27 | |
So , Just put heat protection around the can... |
05-15-2020, 02:38 PM | #28 | |
Chris Last edited by Chris 2018 ZL1 A10; 05-15-2020 at 02:59 PM. |
Thread Tools | |
