Old 01-15-2020, 01:41 PM   #1
OutlawV2
Drives: 2018 ZL1 1LE
The best back drag wheel/tire to run with stock brakes ZL1 1LE
Anyone have any examples of some drag setups for a simple two back wheel setup that I could swap to, to drag race the car...
I'm a drag racer by trade and my car already has Hankook 325/30/19's on the back which are great for lasting beyond the 250 miles the Goodyears will get you...
However they seem almost like barely usable in the first two gears to get this car off the line.... I have an M6 so it's gonna be a bear to get the car down the track.... I had a powerful six speed in the 90s with nitrous but it too was an animal to control once the n2o came on.... MY ZL1 makes like the same amount of torque as THAT car on spray..... LOL...
So I'm all ears. I'd rather not convert my rear brakes and run a 15" combo if I don't need to...
JB
2018 ZL1 1LE Summit White M6
"MOVN WA8" currently stock
2012 CTS-V Diamond White A6 Coupe "Becky"
1995 Z28 1LE 383" LT1 A3 N2O Drag Car 9.06@153
OutlawV2 is offline   Reply With Quote
Old 01-15-2020, 03:15 PM   #2
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Race Star and MT Street R
Old 01-15-2020, 05:44 PM   #3
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG
This;
https://www.summitracing.com/parts/RCE-92-795252DSD
And these;
https://www.summitracing.com/parts/MTT-3572
2018 ZL1-NFG-A10
New Iron L8T
9.37 148MPH
2018ZL1 is offline   Reply With Quote
Old 01-16-2020, 07:25 AM   #4
Fraxum
Fraxum's Avatar
OP with 17" rims on a ZL1 do not hot lap or the caliper will start scratching the inside of the rims. It is a very tight fit. Those rims require special lugs which also need a little light lube on the barrel (not the threads) to install. Next deal with the GM bog.
Old 02-02-2020, 02:53 PM   #5
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
This is what I'm running. No special lugnuts required. Simply use the ones that came with the car. 17x10.5 Race Star Recluse. Hoosier 315/35 DR2 drag radials
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 02-21-2020, 11:03 PM   #6
Markoz28
Drives: 18 ZL1 nightfall grey A10
Any brake clearance pics?
Markoz28 is offline   Reply With Quote
Old 03-19-2020, 12:17 PM   #7
17CamaroZL1
I thought I took some with a light shining in and behind the wheel to show the clearance more clearly, but this is all I can find on my phone. I may have filmed it on my gopro, but I don't have that with me at the moment.
12/26/2016 Ordered!
2/8/2017 Built!!
