Old 07-14-2020, 04:18 PM   #15
TWG1
TWG1
Drives: 2019 Camaro ZLE
So, I too was sick of the dipstick and thought I had a solution. Never panned out: I filed and polished the non-hatched section to a mirror finish thinking it would be like the old chrome sticks. It’s no easier to read than the matte aluminum stock version.
What I have found that works is to not fully seat the dipstick, instead stopping at the o-ring. This will leave it 3/8” above fully inserted, and a “full” reading is then midway in the hatched area. At least this way, you’re looking for a full line on the flat, as opposed to round upper portion above hatched area.
2019 ZLE M6
2019 ZL1 A10 (Sold)
1967 Jaguar XKE Series 1 Roadster
2021 F150 Powerboost (on order)
TWG1 is offline   Reply With Quote
Old 07-14-2020, 05:27 PM   #16
Flowtie1
Drives: 2017 ZL1
I guess I am the odd man out. I don't mind it a bit. Easy to read under the fluorescent lights in the garage.
2017 ZL1 M6 Silver Ice Metallic
Flowtie1 is offline   Reply With Quote
Old 07-14-2020, 07:19 PM   #17
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
I don't mind it either. Just be sure to grease the o-ring so it wont break off like my F150.
getchapull is online now   Reply With Quote
Old 07-14-2020, 09:24 PM   #18
donaldp
Drives: 2017 Red Hot ZL1 M6
Originally Posted by Mark R View Post
Well, I looked for a replacement dipstick, and now I kind of see why they went with the wire unit. Look how convoluted the dipstick tube is. It would probably be quite difficult to get a flat metal dipstick to go down that rabbit hole. Still, the part that one reads the oil level on should be a little longer.
This "Lombard Street" (San Francisco Crookedest Street in the world) tube explains why my dipstick has more oil on one side than on the other when I pull it out to read it. One side is scraping the walls and is wiping off on the way out.
donaldp is offline   Reply With Quote
Old 07-15-2020, 07:11 AM   #19
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
Glad someone posted this, it reminded me to go and check my oil level before I started it yesterday. :-)
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 07-15-2020, 07:46 AM   #20
Allez
Allez's Avatar
I find that wearing one of those headlamps when I'm checking the dipstick makes it pretty easy.
Allez is offline   Reply With Quote
Old 07-15-2020, 08:17 AM   #21
SteveV
SteveV's Avatar
As another person posted, I can definitely read the markings way better with LED lighting rather than florescent of incandescent.
Old 07-15-2020, 08:38 AM   #22
minn19
minn19's Avatar
Drives: 22 ZL1, 20 Taco, 20 Cayenne S
This thread surprised me, I've never had a problem with the stock dipstick.
minn19 is offline   Reply With Quote
Old 07-15-2020, 09:49 AM   #23
Snowwolfe
Drives: CTV5 V Blackwing on order
I went out to the garage and just checked the oil. Sorry guys, I just don't get it. Dip stick is easy to pull out and push in and no difficulty at all reading the oil level. I check the oil in all my vehicles the same way. They sit all night and I pull the stick. No need to even wipe it off.
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 07-15-2020, 11:33 AM   #24
PROMETHEUS
PROMETHEUS's Avatar
Originally Posted by Lafourche1 View Post
It takes a bit of an effort, but what I do is be sure the car has set in the garage over-night. I then pull the dipstick and wipe it off. I then set the dipstick on the side for about 10 minutes. This gives everything a chance to drain down. I then reinsert the dipstick, leave for XX seconds and then pull. This usually gives a better reading. It is a bit of a pain, but it seems to give me a reading fairly consistently. (someone else posted this method and I flat stole it)
Dam....it does give you a better reading! Thanks for the tip.
Old 07-15-2020, 11:59 AM   #25
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
I don't have an issue with the dipstick but it may be another reason why people buy challengers as they have the flat metal type that some like. Like others have posted I have a led head lamp that is 1000 lumen on high lasts 6 hrs on high 35 hours on low when new simply awesome to work with and has a 7yr warranty.
https://www.ledlenserusa.com/collect...14r-2-headlamp
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 07-15-2020, 01:32 PM   #26
minn19
minn19's Avatar
I highly doubt the type of dipstick enters into the thought process of buying one car over another. Maybe not having one like BMWs, but I still doubt it.
Old 07-15-2020, 07:37 PM   #27
closs2sx
closs2sx's Avatar
I was joking but glad someone noticed lol
MY Car
2015 Z06 Z07
Dads Car
2013 ZL1 vin 963
6 Spd Manual
Old 07-16-2020, 08:50 AM   #28
minn19
minn19's Avatar
Thank you!
