Old 06-03-2020, 09:43 PM   #1
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Door locks not working after unplugging body-door harness
First I had the negative off the battery before doing anything.
I unplugged the body-door connector on both sides to route some wires to the door, after replugging the connector and plugging in the battery the lock/unlock would not work through either key fob or buttons inside.
I routed some wires a few days ago without unplugging the connector with no issue but now I’ve had this when I unplugged this connector. I have tried to unplug and plug the connectors (with the negative off) to make sure it’s fully connected and also replaced the battery in the key fob.
My confusion is during a few of my attempts of replugging the negative and spamming the unlock button the locks would work for a few seconds then stop working.
I’ve read that some suggested seeing the BCM fuse but I don’t see an issue with any, I didn’t see any fuse that mentioned locks but I could’ve misread.
https://youtu.be/LKs4EdRoJAs
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Old 06-03-2020, 10:48 PM   #2
Bumbleboy92
Long hauler
Well I guess it just needed some time, works after about an hour of leaving the car
2016 1LT v6
- Totaled
Happiness: Infinite
Old 06-04-2020, 10:27 AM   #3
WorthFlorida
Drives: 2019 Camaro 1SS Convertiable
My take on it as most devices on todays computer cars use a data buss. Each device has an address and it takes a while for the computer to scan its newtork to relearn.
WorthFlorida is offline   Reply With Quote
lock, unlock
