Old 05-21-2020, 08:26 PM   #1
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Opening the door with physical key
I was working on adding an intake and accidentally locked myself out with the battery unplugged, didn’t wanna plug it in as I had the MAF sensor out and was having trouble with the bolt to put it in.
So I tried the physical key I saw some have to use when they were locked out, and it didn’t work. I put the video showing how I was trying to unlock, maybe I’m stupid and doing it wrong but is there a chance I don’t have the correct key?
The car was bought from an auction at 61k and only 1 key included, been using this key since with no issues but never tried the physical key till now
https://youtu.be/kyMOum483Tg
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is online now   Reply With Quote
Old 05-21-2020, 08:50 PM   #2
chaospiece
Drives: 2018 SS, 2016 GT
I've done it before, but I don't understand why it wouldn't work if you bought the car new from the dealer with a cut key.
chaospiece is offline   Reply With Quote
Old 05-21-2020, 09:13 PM   #3
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
There is a good chance that they didn't have the original keys and they bought a replacement key FOB and the key that is in the FOB is not cut correctly.
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
Old 05-22-2020, 01:33 AM   #4
Bumbleboy92
Long hauler
Well I think you hit it right on the head, I forgot that the auction classified it as a repo so it makes sense now.
Now onto seeing if it’s worth getting an actual key made or possible
2016 1LT v6
- Totaled
Happiness: Infinite
Old 05-22-2020, 07:39 AM   #5
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
I'm sure a dealer can get a key cut from the VIN, but it won't be cheap.
17rsvert is offline   Reply With Quote
Old 05-22-2020, 08:27 AM   #6
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
You can actually rebuild the cylinder to match the key if the dealer route of cutting the key is too expensive. Just need a wafer kit like this one: https://www.clksupplies.com/collecti...g-kit-a-23-103
Those kits can be found for cheaper on ebay and other sites, just using that link as an example because the description is pretty well put together. Anything that work with lock cylinder part number 13590041 will work. This door lock cylinder has been used on a ton of different GM vehicle since at least the early 2010s so parts should be easy to find. At first glance the site I linked seems to be the correct one but you'd want to confirm before buying.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 05-22-2020, 11:38 AM   #7
MackSteelPrivateEye
I've used my key with no problem. Are you putting the key in the hole and then turning it.Try the passenger side door. Maybe the car was hit and door was replaced.
Old 05-22-2020, 01:45 PM   #8
Alpha1BC
Alpha1BC's Avatar
OP mentioned that the car was classified as a repo by the auction he bought it from, so chances are whoever prepped the vehicle for sale just bought a fob online and didn't bother matching the key to the cylinder.
2017 SS 1LE.
Old 05-22-2020, 03:42 PM   #9
17rsvert
17rsvert's Avatar
Oh, you're going to repo my car? Here, I want to make sure your happy with it, let me get you both keys before you go. Right.
Old 05-23-2020, 01:20 AM   #10
Bumbleboy92
Long hauler
I'll take a look at the dealer route and the wafer, I have a feeling it'll be too much dough for me. I don't mind much, ordered another remote and two blank keys off eBay for cheap just in case.
I will also try the passenger door tomorrow just in case, if that works then it may be time to take a closer look at the vehicle history lol
2016 1LT v6
- Totaled
Happiness: Infinite
Old 05-24-2020, 07:57 PM   #11
GTO_Gregory
GTO_Gregory's Avatar
Drives: 2016 Camaro
For what it's worth, the dealer will use your one working FOB to program your new FOB(s). I had it done. An extended warranty covered the cost 100%.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff.
2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85.
GTO_Gregory is offline   Reply With Quote
key, locked, physical, wrong
