Old 05-07-2020, 08:46 PM   #1
Shookem
Shookem's Avatar
Drives: 2016 Camaro SS
DSX Baro / IAT Install
I bought the DSXTuning Baro / IAT and I’m trying to figure out where to install the IAT Sensor. Is there a location for it or do I need to make a hole for it?
Shookem is offline   Reply With Quote
Old 05-07-2020, 09:16 PM   #2
aronSlusa
aronSlusa's Avatar
Drives: '16 2SS
Maybe this can help
aronSlusa is offline   Reply With Quote
Old 05-08-2020, 03:18 AM   #3
DorkMissile
DorkMissile's Avatar
Drives: 18 1SS 1LE HyperBlue
Kind of depends on what you are trying to measure with the new IAT sensor.
I am using one, and since I am using meth injection it is setup behind the throttle body in the intake to read the air temp after the meth is mixed with the air.
I just drilled and tapped my plastic intake for the thread on the temp sensor, sealed with 297 Loctite thread sealer and it was done.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
DorkMissile is offline   Reply With Quote
Old 05-08-2020, 05:26 PM   #4
Shookem
Shookem's Avatar
Same thing I’m going after. Tuner I’m working with said he wants to measure Meth IAT Temps so I’m going to go into the intake right behind the throttle body. Do you happen to recall what size tap you used?
Old 05-10-2020, 07:56 PM   #5
New_image
Drives: 2019 Camaro 1LE
M14x1.5
New_image is offline   Reply With Quote
Old 07-02-2020, 11:30 PM   #6
GN_Drake
Thread helped. Installed with ease! Appreciated
GN_Drake is offline   Reply With Quote
