01-27-2020, 10:18 AM | #29 | |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Baby Blue
01-27-2020, 04:49 PM | #30 |
Drives: 2018 SS 1LE Join Date: Aug 2017
That's good to hear. I've been reading a lot more posts about supercharging the LT1. I just ordered a catch can and a Metco breather. I'm hoping I won't have anymore oil leaks after installing them. I'm happy with the power I have now with the stock tune.
01-28-2020, 10:04 AM | #31 | |
My recommendation would be to either get a Mighty Mouse catch can system or at least a Metco valve cover breather with check valve. Also you should get it custom tuned as I mentioned earlier by someone who understands DI systems. Ted Jenetty, Pray Performance, EFX tuning...etc all can get you sorted with remote tuning. You should also consider a AEM wideband and verify your fueling is in the .82 Lambda range at WOT and fluctuating around 1.0 at part idle/part throttle. Bryan Herter @ PCM for Less.
2016 NFG 1SS A8
06-20-2020, 06:48 AM | #32 |
Drives: . Join Date: Jan 2017
06-20-2020, 08:25 AM | #33 |
Man I am sorry to hear all the problems you've had no matter what blower your running no one needs to go thru the issues you have. Good luck and hope someone gets it straightened out, I've not heard of anyone having the issues you've had with any canned tune or a shop trying to fix it.
06-23-2020, 09:20 PM | #34 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
This sucks. My Whippled truck actually ran great with the canned tune. Times confirmed. Custom now though.
06-25-2020, 02:32 PM | #35 |
Car is ready pick her up tomorrow hoping for best. Vid will be posted of final pull...
06-25-2020, 05:26 PM | #36 |
06-25-2020, 09:09 PM | #37 |
Subscribed
06-25-2020, 09:41 PM | #38 |
Drives: SS 6 speed of course Join Date: Jan 2016
I've "broken" cars that come in for a dyno (back in the day). I'd let the customer know, hey the car blew up, be up-front and as honest as possible. My gut feeling is there is no sticking ring, one cylinder is bad and it is intermittent, keep running the motor and the engine will lock up and then toss the rod out the block. Any good shop would have a bore scope and look for the tell tail wear marks of a broken ring land / seized ring. Remmember it is not the rod bolt breaking and the rod flying out, it is the piston locking into the bore that fails the rod bolt then the rod flies through the block.
06-26-2020, 11:58 AM | #39 | |
Really hoping for best. I sure don't need my motor blowing up the 2nd day home. |
06-26-2020, 09:51 PM | #40 |
Good luck and keep us posted.
07-01-2020, 09:40 AM | #41 |
07-01-2020, 12:35 PM | #42 |
Good to hear.
Thread Tools | |
