05-28-2019, 12:19 PM | #1 |
Drives: 2019 Camaro SS 1LE Join Date: May 2019
BEST lowering SPRINGS?
I HAVE A 1LE,I just want to know basically Which springs will lower my car the most and it not affecting MRS. Please help...
05-28-2019, 12:29 PM | #2 |
powell raceshop yyz if you looking for best handling...if you want lowest that is a different question
05-28-2019, 12:36 PM | #3 |
Drives: 19' Camaro 1LE Join Date: Feb 2019
Eibach are pretty good on the handling, visually pleasing... not the lowest either. For being a mainstream brand, I was quite surprise on the quality.
2019 SS 1LE
American Racing Headers, No cats Airforce Intake Manifold Roto-Fab Intake E85 Flex-Fuel Eibach Pro-Kit GP Tuned |
05-28-2019, 12:46 PM | #4 |
05-28-2019, 12:48 PM | #5 |
I want to go as low as possible but not affect MRS. If it's a full inch, then It is what it is, if its only half an Inch... that is fine too. But I figured maybe someone in here with a 1Le has a nice drop and car still runs nice on track.
05-28-2019, 01:13 PM | #6 | |
lol i seen a 1le on ig lately that is bagged...im sure he gets alot of hate
05-31-2019, 09:36 AM | #7 |
Drives: camaro Join Date: May 2016
Does anyone use this?
https://wildhammermotorsports.com/16...kit-lt-ss-h-r/ |
06-04-2019, 08:00 AM | #8 |
actualy for SS 1LE is this one: https://wildhammermotorsports.com/16...pring-kit-h-r/
anyone have any feedback? |
06-04-2019, 08:19 AM | #9 | |
Drives: ISO ss 1le Join Date: May 2018
06-04-2019, 08:30 AM | #10 |
Drives: 2SS 1LE Join Date: Oct 2011
The ones that come with coilovers so you can match the correct damping rates?
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
06-04-2019, 08:44 AM | #11 |
Drives: E92 BMW M3 Join Date: Oct 2012
A couple helpful threads already here, just search "Lowering Springs" in this sub-forum.
Just know you cannot lower the car without affecting the MRC. Only you can decide what is enough drop, and how much difference(affect) is acceptable.
J-Rod Built and Matt@FSP Tuned |
06-04-2019, 09:39 AM | #12 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2019
That is my fear mucking up an ready good suspension setup. I want to get the center of gravity down a bit... The H&R site says the 1LE springs drops the car 1.25 inches. That seems like a lot...
06-04-2019, 01:19 PM | #13 |
Changing springs will compromise the handling, period. But if it is just a street driven car, the change will not even be noticeable. If you are only effecting a handling characteristic that shows itself at speeds you wont reach, then who cares right? Just depends on your intended use. I lowered my 5th Gen, and would lower a 6th Gen too if it was just a street car. It will still be an amazing machine on the streets, believe it.
06-04-2019, 06:40 PM | #14 |
I've been told the best track springs designed to work with MRC are the YYZ springs. They have a 1" drop
https://zzperformance.com/collection...racing-springs |
