11-07-2017, 07:39 AM | #1 |
RUSH TWO
Drives: 2014 Camaro 2SS/RS Join Date: Aug 2010
2014 Hood Heat extractor
I recently installed an LSA in my car. I knew there was a hood heat extractor fit issue. I put some hard rubber washers between the hood and extractor and gave myself some added clearance. I used some rubber weather stripping to fill the gap. I am a little concerned that the hood gets pretty hot and wondering if this might melt. what do you all think
thanks in advance
Window tint, Clear bra, 1 7/8 Headers with Hi-flow cats, ADM Performance-CAI, Slotted/Drilled Rotors with Ceramic carbon fiber pads. Painted Calipers, Drag wheels, Outlaw Catback Quad tips, CFD Shifter with Leather boot upgrade, LSA Supercharger, AEM AFR Gauge |
11-07-2017, 08:58 AM | #2 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
I think it's a cool solution, and from the pic looks pretty good. Can you post another a bit further out in good light? Looking for a solution too. Don't think the engine heat will be enough in that area to melt that either. If in doubt, buy a cheap laser thermometer. Did you get all the clearance you needed?
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
11-07-2017, 09:50 AM | #3 |
RUSH TWO
I will take a far back picture when I get home tonight.
It looks pretty good, you would not be able to tell if you were not looking for it or did not know it was adjusted.. Yes I did get more clearance So I am satisfied with it
