08-02-2016, 08:47 AM | #1 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
Camaro 6th Generation ACS V6 LT LS ACS-T7 Splitter Now At RPI Designs
2016-2018 Camaro 6th Generation ACS V6 LT LS ACS-T7 Splitter
http://www.rpidesigns.com/shop/item....s-t7-splitter/ The latest Gen6 Camaro is simply stunning, won't take long to realize that a new front splitter will set it to a new level. Not only will it add an extra visual dimension to the car’s sleek build, but it will add aerodynamics and guile at high speed to a vehicle that already handles like a dream. Available in a black primer finish, or Any 6th Generation Camaro Body Color. The Gen6 Camaro Splitter carries the following features as standard: Improved frontal airflow management Manufactured in an OEM-validated RTM composite material Use of OEM mounting points for simple installation. For those that love to adorn the car themselves. You will be pleased to know that installation is less than 15 minutes; the ACS-T7 Splitter is installed using the OEM mounting bolts. Fits all 2016 Camaro I4 & V6 front fascias. Winglets have over the last few decades been used by both commercial and corporate jets. Jet designers have long known that airflow off the end of a wing caused drag. With the implementation of the winglet, airflow was improved and planes moved more efficiently. The same principle applies to the latest Camaro Winglets / Deflectors line. Application Guide Camaro I4, V6 2016-17 Coupe, Convertible. Last edited by RPI Designs; 02-05-2018 at 02:08 PM. |
12-10-2020, 08:48 AM | #2 |
11-14-2021, 09:08 AM | #3 |
Thread Tools | |
