11-21-2022, 07:54 PM | #1 |
Drives: 2022 Camaro LT1 Join Date: Nov 2022
Lug nuts
Does MRR wheels is 60 degree conical lug nuts ? Need to order a se for new wheels
11-21-2022, 09:23 PM | #2 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
My MRRs are a different model, but they are 60-degree conical. I'm sure they all are if they are intended for a Camaro.
Matt Miller
2020 SS 1LE |
11-22-2022, 04:06 PM | #3 | |
I’ll also add that I recall that MRR wheels required a smaller lug nut. I don’t know if that’s the case with your wheels. Did MRR recommend a smaller diameter lug nut?
11-22-2022, 05:43 PM | #4 |
These wheels look like the forged MRR FS01 model, these are strong and look good, if this is what you're contemplating. All MRR wheels I've seen use 60 degree conical lug nuts, BUT you need smaller outer diameter ones, stock lug nuts will not fit (yes, I tried , although with the MRR M017, not this one).
Here is an option, Phastek sells compatible Gorilla locking lug nut sets: https://www.phastekperformance.com/C...-locks-blk.htm. I'm not overly fascinated with these, they get a little rusty over time, just FYI if that bothers you. I switched to McGard (sold at 2x the price) in the meantime and those are flawless.
11-22-2022, 06:59 PM | #5 |
Glad that arpad and Trochoidal mentioned the smaller lug nut diameter. This is true of my MRRs, and again just looking at the pictures of your wheels, I'm sure they will too. On our cars, that means going from the stock nut's 21mm hex wrench size down to 19mm (or 3/4") or getting a splined lug nut like the ones arpad linked. Obviously you need to keep the M14x1.5 thread on the inside.
Matt Miller
2020 SS 1LE |
11-23-2022, 06:46 AM | #6 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
When I ordered my MRR's I specifically opted in to their lugnuts knowing that they had something different, that the OE nuts weren't going to work. What I got is a 60degree conical splined lugnut.
11-23-2022, 07:06 AM | #7 |
Thanks guys. I ordered a set of splined lug nuts yesterday.
11-23-2022, 07:07 AM | #8 |
