11-21-2022, 06:12 AM | #1 |
Drives: 2021 Camaro ZL1 A10 Join Date: Jul 2021
Help with NW 103 TB MAP Sensor Connector Clearance
Anyone run into this issue when installing a Nick Williams 103mm Throttle Body on the LT4.
Kong Standard Port LT4 Supercharger. Seems the MAP (TIAP) Sensor Connector hits the cover and wont mount. When I disconnect the connector it mounts just fine, but with the connector it hit? Any suggestions? Thank you for your help! |
11-21-2022, 11:53 AM | #2 |
Drives: 2015 Camaro ZL1 Join Date: Oct 2020
Take the retaining bolt out of the sensor and rotate the sensor so the retaining bolt now fits into the corner of the sensor instead of the hole.
11-21-2022, 03:39 PM | #3 |
Solved! Thanks to Katech_Mike!
Thanks Katech_Mike that seemed to do the trick! Everything fits now and the build is starting to look much better!
Thanks again. Photos of the Fix....... |
11-21-2022, 03:42 PM | #4 |
Show Shot
Here is the shot of the ZL1 Jewelry Installed.....
