09-23-2022, 01:58 PM | #1 |
Drives: 2011 Camaro SS LS3 Join Date: Jul 2018
1986 Z28 Bracket ROLLER
I'm selling my 86 Camaro bracket car, its time to go big tire and I dont have the time and tools to cut this one up. It will make a great starter car for bracket racing.
*New Lakewood 90/10 drag struts, just bought this year *Jegs 15x4 front wheels, MT 26x4-15 front runners. 15x10 Weld Draglite rear wheels, 28x10.5-15 MT ET Drag slicks with plenty of life left *6in fiberglass cowl hood w/ hood pins *Disc brakes front/rear, line lock front/rear. REAR LINE LOCK IS NOT HOOKED UP *S10 manual gearbox w/ Ed Quay steering damper *Front mounted 3gal fuel cell *Electric cooling fan * 8 point rollbar, weld in subframe connectors *Mallory Hyfire VI ignition box *Batteries have been relocated to rear of car, has exterior posts and battery kill switch * 12 bolt GM Moser Housing w/ 35 spline Moser axles. Has 4.56 pro gears w/spool *Ladder Bar suspension, single adjustable coil over shocks I also have a set of 15x8 wheels to match the fronts with a set of 275/60/15 Pro Bracket Radials that can be bought for extra. Fuel pump/filter, shifter, and delay box are not for sale and will be removed with engine and trans at time of sale. Located in Hardinsburg, KY 40143 $10,500 obo. Local pickup only, will meet within a reasonable distance if necessary. Last edited by SpartanB482; 09-27-2022 at 11:46 AM. Reason: Price Drop |
