05-06-2022, 12:44 PM | #1 |
Drives: Camaro 2021 2SS 1LE Join Date: Mar 2021
Changing Rear End Fluid 2021 SS 1LE
Good afternoon,
Is this the correct stuff for the rear diff? https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1 Thanks in advance. G |
05-06-2022, 01:54 PM | #2 |
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
05-06-2022, 02:57 PM | #3 |
Osbornsm's answer is correct, the 10-4034 fluid already has the limited slip friction modifier mixed in. If you buy the other one, you'll need to add it yourself separately.
05-06-2022, 04:13 PM | #4 |
Thank you gentlemen.
R |
11-03-2022, 11:53 AM | #5 |
Drives: '22 Camaro 2SS/1LE Join Date: Nov 2021
Without opening a new thread and the search feature being unavailable right now, is Osbornsm link the same for a '22 M6 SS 1LE. I put my Camaro model in the Amazon 'confirmed fit' thingamajig and it says it doesn't fit my car.
Thank ya! Edited to add: how many qts? (I know this is all prob in my manual, but I don't have that on hand right now) Thanks again!
'22 2SS/1LE, M6, Wild Cherry Tintcoat, PDR, Sunroof
11/1 - order submitted to GM - 12/26 - order accepted by GM 1/7 - TPW 1/24 1/13 - TPW 1/31 2/9 - 3800 - BUILT! 3/2 - 4300 3/14 - 4B00 3/19 - per Chevy chat - finishing up final testing and approvals - dealership ETA 4/16/22 3/29 - 4200 - dealer ETA 4/23 4/5 - 5000 - but can't pick up for another week 4/16 - 6000 - Home Sweet Home Daily driver... '23 Mazda CX5/Premium Plus (dealer demo) |
11-03-2022, 01:27 PM | #6 | |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
11-04-2022, 02:02 PM | #7 |
Thank you!
11-09-2022, 01:16 PM | #8 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Note that capacity is 1.6 quarts. After draining, fill until it starts to overflow a bit then tighten the fill plug to 24 lb ft. Drain plug is also 24 lb ft. This info is for the 226mm eLSD which is found in the SS 1LE and ZL1.
For the 200mm (Non-Limited Slip) and 225mm (mLSD, Limited Slip) axles, the value is 33 lb ft for both drain and fill plugs. They both have a 1.2 quart capacity. |
11-09-2022, 06:15 PM | #9 |
Drives: 2022 1SS 1LE M6 Join Date: Feb 2022
Good info, I managed 508 miles on my 22 1SS 1LE this year prior to to the weather changing and will be swapping the diff and engine oil.
2022 1SS 1LE M6 ordered 31 Jan 22
Picked up 20 Aug 22 |
Thread Tools | |
